jhutchison
Problems with PrintoPDF
PrintoPDF works fine with 8.5.2. If using PrintoPDF with VA9, the resulting pdf file created is 4k with no data (just a white sheet). Anyone else experience this problem?
I have been getting the same result with VW9 (Printtopdf worked fine with VW8.x). I am guessing the Nemetschek is well aware of this at this time, but it doesn't hurt to add your voice.
I did some tests. I was using vesion 2.2 with VA9, and it did not work. However, I downgraded to version 2.1.5, and it now works fine. Strange.
quote:
What is "PrintoPDF"? it sounds like something I could use like the AutoCAD "plt" file. I want to be able to export PDFs of VW9. Does anyone have any suggestions?
Ben
If you have a Mac, you can just use PDFwriter or Acrobat Distiller from Adobe, or Print2PDF - they work like a virtual printer. The file generated is a obviously a .pdf-file.
As far as I know, Adobe's Products are available at least for NT4, W98.
Since I turned away from Microsoft, I can only inform you about these old OS's.
On a PC you can go to a site called www.ctrlp.com and down load a free pdf writer. I cant remember the applications name but I use it all the time. It simply installs another printer that you can choose under you print options. When you use it it puts a pdf on your desktop.
I think you have to reqister with the site, Its some kind of printer service in England.
Good luck
