Hello Community!
This Saturday, May 30, from 9am – 12pm EDT we will be performing maintenance on the Vectorworks Community Board. During this time, the site will be unavailable.
Eric Myers
Apply Textures
I've been having issues with applying textures to objects for rendering. Today I'm working with some text I've extruded and have tried unsuccessfully to apply different textures - the text always renders white (or grey) no matter what color the texture is that I've applied. I've also changed the Map Type and flipped my text object to see if the texture was being applied to the opposite side, but to no avail.
Does any one have any suggestions to help me work through this issue?
Thanks.
It is likely that the extrude is set to Use Class Texture. Go to the Render tab of the Object Info Palette and pick a texture there.
If that does not work, double click on the extrude, select all of the polylines and make sure that they are set to have a solid fill.
I have chosen various textures under the Render Tab, some defaults and some created by me, all with no luck. I did not think about looking at the attribute settings, but it was already set to solid. Trying a quick (relative term based on my hardware) render using a different attribute color to see what kind of results I get, but would still like to use textures as opposed to flat colors when possible.
Copy and Paste one of the extruded letters into a new file and post it here, we'll be able to figure out what's wrong.
I just opened your file and I'm able to apply textures to any of the letters through both the OIP and the resource browser. Here is the file.
Thanks for your help with this...
I've tried downloading your file twice, and aside from it having a different file name (1869), VectorWorks claims it is unreadable (I'm using 2008, btw). Also, my issue is not applying the textures, it's getting them to render properly with the textures I've chosen. Were you able to render the textures?
Ray would need to know how you intend to manipulate then render the textures.
If you use "Planar" mapping then the texture will only be correct on the face chosen but you will be able to use the Attribute Mapping tool to adjust, if you change to "Perimeter" Mapping then you will have to rely on the Offset parameters and Rotation to adjust.
If you go to the Render Tab of the Object Info Palette you can change the Texture for the Group of Letters and it should render as desired.
The issue I think your facing is that the Letters can have a solid fill as well as a Texture for Rendering under the Render Tab. If you Assigned a Texture then it will override the Fill color in a 3d view. The Letter needs a fill though in order for it to Render the Texture chosen. You can change the "Letter" Texture to any material of your choice but would suggest using names to textures that are associated to the actual texture, for instance Metal Chrome or Metal Cast Aluminum.
The file is version 2009.
It would help if you would create a signature with your version of Vectorworks and computer specs.
Here is the 2008 version of the file.
Thanks to everyone for their help and suggestions. Today I opened the file and it rendered the text exactly as it should have. This was after opening the file from Ray (thanks) so I don't know if that jogged something in my app settings or not, but I didn't have to make any changes to my file to get it working today.
