drmdzh Posted December 21, 2008 Share Posted December 21, 2008 Just upgraded from 12.5 to 2009. Haven't used the program in a year (have been designing costumes)but now back to it. I have a REALLY simple question. It used to be that I could draw a polygon with the 2d polygon tool, or rectangle, etc and then extrude and I'd have a nice solid object. Now however, I only ever get a wireframe when I extrude. All of my stuff from 12.5 is rendered with textures and everything, but I can't seem to get anything but wireframes now. What changed? What do I need to do now to convert a 2d polygon into a solid object? What is extrude for, if not for that? very confused, thanks in advance. Quote Link to comment
Ray Libby Posted December 21, 2008 Share Posted December 21, 2008 It sounds like your polygon isn't closed. You could post a file here with an example to troubleshoot. Quote Link to comment
gmm18 Posted December 21, 2008 Share Posted December 21, 2008 And remember that if you are in Wireframe rendering mode, then an extrude does appear in wireframe, If you want it to have solid fills on all 6 sides then you must use another rendering mode such as OpenGL, HiddenLine, etc. That is just how extrudes work, it is not different from VW12 to VW2009. Some Plug-in-Objects, such as a Floor Object for example, will display its fill properties in Top/Plan view, but a simple extruded shape will appear with no fill in Top/Plan view. Simple questions are good, keep posting them as you are surely not alone. Quote Link to comment
drmdzh Posted December 21, 2008 Author Share Posted December 21, 2008 Thanks all. Here's the object file. I've rendered it in OpenGL. I used the polygon and rectangle tool to make the 2D objects, so I'm pretty sure they are not open. Then extruded. They will only appear in wireframe (even in the other document I took them from where everything else is rendered fine) Quote Link to comment
GWS Posted December 21, 2008 Share Posted December 21, 2008 If you select the object in question and then go to your attributes palate and select solid from the drop down menu next to the bucket icon you should get a solid object appear. It worked for me. Quote Link to comment
drmdzh Posted December 22, 2008 Author Share Posted December 22, 2008 Wow. I never had to do that before. That was easy, thanks so much. Quote Link to comment
