beanus
door & window ID labels
when labelling windows with the ID label the labels seem to appear in a radom position,is this a bug or just me?
It seems to work fine for me.
First click is where you want the label to be. The second click is on the door/window you want to label.
The labels are always centered on the first click.
thats exactly what I do but the labels dont appear where I click they seem to be offset from that point. The drawing was originally created in version 2008
Could you have gotten a bunch of spaces in the Prefix of Suffix fields of the drawing label tool?
Select one door/window and go to Settings and turn on the box around the label. This could help point out where your offset is coming from.
no checked that, I've now started doing the doors & this is what happens with ID label set to horizontal? (see attachment)
It looks as though your plan is in a rotated view... is this correct? If so, I do believe this to be a bug. If I were you I would return the drawing to top/plan to use this tool.
Can you try in a new file and see if you get the same results?
in VW2009 SP1, I can only duplicate your problem with the rotated working plane.
Pat
