GWS Posted December 19, 2008 Share Posted December 19, 2008 I have 3 lofted surfaces that I have add together into 1 object. Does anyone know if it's possible to make this a full solid item? I have chopped off the end with a subtraction to show that it is hollow. Please see attached. (When I take it into 'Inventor' or 'Solidworks' it becomes solid) Guy Quote Link to comment
Ray Libby Posted December 19, 2008 Share Posted December 19, 2008 Why do you need it to be solid? Quote Link to comment
GWS Posted December 19, 2008 Author Share Posted December 19, 2008 I'd like to put a recess on the back surface and then 3D print it. Quote Link to comment
Pat Stanford Posted December 19, 2008 Share Posted December 19, 2008 The easiest way would be to go back and redo the Loft and check the Create Solids check box in the Loft dialog box. The other possibility is to make sure you have a closed object using the Trim and Stitch Surfaced command. This should convert your NURBs surfaces into a Generic Solid that will show as solid when you do other solids operations. Quote Link to comment
GWS Posted December 20, 2008 Author Share Posted December 20, 2008 I did check the 'create solids' check box but to no avail and the 'Trim and Stitch Surfaced command' failed. I also tried creating a nurbs curve and using the protrusion tool in add mode unfortunately that didn't work. Quote Link to comment
Pat Stanford Posted December 20, 2008 Share Posted December 20, 2008 Can you send me a file with just the objects in it (and the original curves you used to do the loft if appropriate) and I will take a look. Send it to the address in my signature. Quote Link to comment
GWS Posted December 20, 2008 Author Share Posted December 20, 2008 Thanks Pat, will do. Quote Link to comment
