HP Sauce Posted December 16, 2008 Share Posted December 16, 2008 Despite having lights in the drawing, the vis window refuses to show them. They're there if you click in the empty space, visible if only for a second, but there nonetheless. This makes the entire vis window useless, obviously. What's causing this? Quote Link to comment
Donne Martin Posted December 16, 2008 Share Posted December 16, 2008 Highpass, The bug seems to occur with files that have a sheet layer as the active layer AND one of the following happens: 1) You drag the file onto the Vectorworks executable to launch the application and the file together, or 2) You switch workspaces while a sheet layer is the active layer. As a workaround, please launch the application first then open the file. You can also try to avoid switching workspaces while a sheet layer is the active layer (ie switch to a design layer first). We hope to resolve this bug in an upcoming release. Thanks Donne Quote Link to comment
