Alan w
How do you get the perimeter length of a 3D polygon?
When you draw a 2D polygon it tells you the perimeter length in the object info window, as soon as you convert that into a 3D polygon it only tells you the Surface area and the perimeter length disappears
4 answers to this question
Yes, so it seems. There is no "perimeter" for a 3D poly but surely the OI should report the actual "length" of one, shouldn't it?
Yes, yes: the sum of lengths of 3D edges...Do you really think that I don't have a script for quantifying this? Unfortunately Mr. NNA finds this too hard.
Well, a script is definitely a workaround.... The only good thing is that one can copy & paste the value. I wrote the original one to measure 3D-polys that were on the surface of DTMs and represented eg. walking paths.
Added handling of closed 3D-polys just now.
PROCEDURE LengthOf3DPoly; { ? Petri Sakkinen 1995-2008 }
VAR
x, y, z, x1, y1, z1, x2, y2, z2, d, h, l, total : REAL;
n, i : INTEGER;
obHd : HANDLE;
BEGIN
obHd := FSACTLAYER;
	IF GETTYPE(obHd) = 25 THEN BEGIN
		n := GETVERTNUM(obHd)-2;
		FOR i := 0 TO n DO BEGIN
			GETPOLYPT3D(obHd, i, x1, y1, z1);
			z := z+z1;
			GETPOLYPT3D(obHd, i+1, x2, y2, z2);
			d := DISTANCE(x1, y1, x2, y2);
			h := z2-z;
			l := SQRT(d^2+h^2);
			total := total+l;
		END;
		IF ISPOLYCLOSED(obHd) THEN BEGIN
			z := z+z1;
			GETPOLYPT3D(obHd, 0, x2, y2, z2);
			h := z2-z;
			l := SQRT(d^2+h^2);
			total := total+l;
		END;
	END;
total := REALDIALOG('Length', NUM2STRF(total));
END;
RUN(LengthOf3DPoly);
