Is there way to use VS to set Attributes Palettes properties?
mike mcneil
On occasion I will override the object creation method (either fill type, line type, color, etc.) in the Attributes Palette when I am creating a viewport frame or polyline, etc. Is there a way via a script to set those properties back to "by class" rather than having to select each property individually in the Attributes Palette. I am not trying to modify an existing object, but I would like to have the default creation method set back to "by class" for every attribute.
Thanks for your help.
Take a close look at the Attributes Palette. Every setting there has an option for "By Class". The all have a little black arrow pointing to the upper right in them.
Just take the parameter that needs to use the class attributes and set that attribute to the "By Class" option.
This works for any object, not just those created with "Class Attributes" turned on at their creation.
Not sure if it's this what you need, but if you use this script, the next (and all folowing) objects will be drawn "by class". I use it quiete a lot because i got many external drawings that where the standard attributes aren't "by class".
[font:Courier New]LSByClass;
PenColorByClass;
LWByClass;
FPatByClass;
FillColorByClass;
OpacityByClass;[/font]
I use this script to set back to class, I have gave it a shortcut (shift command option a) and it sets the object to class or the pallette if nothing is seleted to class defaults.
The only thing I would like to see improved in this script is the opacity and arrow to be set to class also.
{Developed ?2003 Katerina Panagiotakis}
Procedure Classdf;
var
x,y,xo,yo: Real;
h,oh,h0,hp,hx,ha,hg: Handle;
message:integer;
begin
ha:=LSActLayer;
GetOrigin(xo,yo);
Locus(-xo,-yo);
h0:=LNewObj;
hp:=GetParent(h0);
DelObject(h0);
if GetType(hp)<>11 then begin
if ha<>nil then begin
ha := FSACTLAYER;
WHILE ha <> NIL DO BEGIN;
SetLWByClass(ha);
SetPenColorByClass(ha);
SetfillColorByClass(ha);
SetfpatByClass(ha);
SetlsByClass(ha);
ha := NEXTSOBJ(ha);
end;
end;
end;
if GetType(hp)=11 then begin
hg:=FInGroup(hp);
ha := NextSObj(hg);
if Selected(hg) = true then begin
SetLWByClass(hg);
SetPenColorByClass(hg);
SetfpatByClass(ha);
SetlsByClass(ha);
end;
ha := NextSObj(hg);
SetLWByClass(ha);
SetfpatByClass(ha);
SetlsByClass(ha);
ha := NEXTSOBJ(ha);
end;
end;
end;
LSByClass;
LWByClass;
PenColorByClass;
FillColorByClass;
FPatByClass;
ReDrawAll;
end;
Run(Classdf);
John,
Ask and you shall receive.
This version also sets the marker and opacity to be by class.
One correction to the description though. This script always sets the defaults to ByClass even if another object is selected when you run it. It could be modified to not do so if so desired.
{Opacity and marker by class added 2008 Pat Stanford}
Procedure Classdf;
var
x,y,xo,yo: Real;
message:integer;
begin
ha:=LSActLayer;
GetOrigin(xo,yo);
Locus(-xo,-yo);
h0:=LNewObj;
hp:=GetParent(h0);
DelObject(h0);
ha := FSACTLAYER;
SetLWByClass(ha);
SetfpatByClass(ha);
SetlsByClass(ha);
SetMarkerByClass(ha); {Added Pat Stanford 2008}
SetOpacityByClass(ha); {Added Pat Stanford 2008}
ha := NEXTSOBJ(ha);
end;
end;
end;
hg:=FInGroup(hp);
ha := NextSObj(hg);
SetLWByClass(hg);
SetfpatByClass(ha);
SetlsByClass(ha);
SetMarkerByClass(ha); {added Pat Stanford 2008}
SetOpacityByClass(ha); {added Pat Stanford 2008}
end;
ha := NextSObj(hg);
SetLWByClass(ha);
SetfpatByClass(ha);
SetlsByClass(ha);
ha := NEXTSOBJ(ha);
end;
end;
end;
LSByClass;
LWByClass;
PenColorByClass;
FillColorByClass;
FPatByClass;
MarkerByClass; {added Pat Stanford 2008}
OpacityByClass; {added Pat Stanford 2008}
ReDrawAll;
end;
Run(Classdf);
  • 3 months later...
  • 11 years later...
