RubenH Posted December 20, 2008 Share Posted December 20, 2008 (edited) It worked as you said Pat... The difference is that I was using the Issue Manager to change the Drawing Number.In that way it doesn't work. If I edit it using the double click and enter directly in the title block it works! Anyway, It should work with The Issue Manager, too. It doesn't work if you create a Report and use a worksheet's cell to edit the field, I think it should, too. Thanks again. Edited December 20, 2008 by Mr. Gog Quote Link to comment
Pat Stanford Posted December 20, 2008 Share Posted December 20, 2008 My guess is that the Drawing labels are not recognizing that the border has been updated when it is done via a "script" (another PIO or a change in the worksheet). No, it is worse than that. It appears that there are multiple records attached to the border/title block. When you update it through the worksheet, it only updates part way and the label does not get the correct information. I would go ahead and report it as a bug if this is functionality you think you really need. I don't use the Issue Manager, so I couldn't test that, but it is probably the same thing. Quote Link to comment
