Tim Perks Posted December 9, 2008 Share Posted December 9, 2008 Why is the window object tool creating windows with a solid fill? It is not controlled by a class or any of the settings I can find in the tool itself. I working with a black background, and the windows are being created with a solid white fill. Quote Link to comment
panthony Posted December 9, 2008 Share Posted December 9, 2008 In the window settings dialog under the view tab check the glazing setting. Quote Link to comment
Tim Perks Posted December 10, 2008 Author Share Posted December 10, 2008 It's not just filling the window, the entire area occupied the window, including the jambs and sill, are filled solid. Quote Link to comment
Pat Stanford Posted December 10, 2008 Share Posted December 10, 2008 Select the window and look in the Object Info Palette. Does it say Window or Window in Wall? If it is Window in Wall, then there is something else wrong. If it say Window, then the window did not get placed in the wall. Drag it away from the wall and then back in, making sure the tip of the mouse pointer is between the wall lines when you release it. This will make sure it is inserted in the wall. Pat Quote Link to comment
mr. iagea Posted December 10, 2008 Share Posted December 10, 2008 Tim, to solve your trouble with the windows (frame, jamb and sills) being filled solid, be sure that you have a class assigned to the windows, and that class reflects the attributes that you want for your windows. For example, if you want your frames to be colored, then make a new class, set the fill color to solid, and select the color you want. Then, assign that class to each window (you can also set the default by double-clicking the Window Tool, then clicking the "Settings" button to set all the attributes of all subsequently placed windows. The glazing setting (In the "View" subsection of the Window Prefs) seems to be a sticky bit. See my post today "Window Glazing/Style Classes". I have come up with a solution for the glazing, but it's still frustrating that a new transparent class needs to be created and assigned because the existing clear attribute option in the Window Preferences pane doesn't work. At least this is the case for my install. Yours may be working. Is it? Quote Link to comment
Tim Perks Posted December 10, 2008 Author Share Posted December 10, 2008 I'm stumped. Tried your suggestion and it didn't work. No matter what I try, the window is always filled solid. Quote Link to comment
mr. iagea Posted December 10, 2008 Share Posted December 10, 2008 Even with Pat's suggestion? I'm pretty sure it won't work if the window is not properly placed in a wall. Can you re-create the problem in a fresh file? I'd try that with a new wall section, and window settings set up as described earlier. And, until you go through the process of setting the glazing class, as described in my earlier post, the glazing itself will be opaque. Quote Link to comment
Tim Perks Posted December 10, 2008 Author Share Posted December 10, 2008 I can recreate the problem. This is not a 3d problem, this is in plan view. The windows are properly placed in the wall. The problem isn't the glazing, the entire window object is opaque. If the wall is drawn with a thick line weight, it really noticeable because the window object covers half of the line. Quote Link to comment
mr. iagea Posted December 10, 2008 Share Posted December 10, 2008 I'm not sure I understand, then. Without seeing the problem, it's hard to say, if these suggestions aren't fixing it. Does the window appear to render properly in 3D view? Quote Link to comment
ccw Posted December 11, 2008 Share Posted December 11, 2008 (edited) I agree with Pat. It sounds like the window is not placed in the wall correctly. I had the same problem not too long ago, it turned out that as I dragged the window along the wall. I accidently pulled it out of the wall. It still appeared to be in the wall, but when I rendered it the wall appeared solid. Edited December 11, 2008 by ccw Quote Link to comment
mendezarcediego Posted November 28, 2017 Share Posted November 28, 2017 I have the same issue as @Tim Perks(correct me if I'm wrong), just to be clear, it is a "know how" issue. This not a 3D render issue, it's a 2D graphic representation problem. If we are on the same channel, what we need is to know how change the 2D graphic representation of individual window elements. In my case I want to show the window frames in a solid black fill and the rest in white fill. Does anyone know how to achieve that? Quote Link to comment
Gadzooks Posted November 29, 2017 Share Posted November 29, 2017 Hi @mendezarcediego - this forum gets more and more powerful - I started reading the thread and realised I was back in 2008. However, your problem is more current so.. You have set the line and fill type as class styles. Is this your requirement? I'm not 100% sure what you are after here, but just to change the fill to black and the line to white will maybe provide your solution? Can't think it will be that easy but lets look at it from that direction first! I note your walls are black - is that intentional also? Come back if I've totally misunderstood. If its more complicated a file will usually help. Quote Link to comment
mendezarcediego Posted November 29, 2017 Share Posted November 29, 2017 Hi @Gadzooks, thanks for the reply, not quite what I'm after. The attributes control the appearance of the WHOLE window, I would like to control the appearance of independent elements WITHIN the window in order to have the frame cut fill appear as solid and the rest as white such as in the sketch: Quote Link to comment
Vectorworks, Inc Employee PVA - Admin Posted November 29, 2017 Vectorworks, Inc Employee Share Posted November 29, 2017 If you change the option under 2D Visualization from Set Attributes By: Object to Class, you can then separately class the individual window components and the class fills will be used to control the component attributes: 1 Quote Link to comment
SamO Posted February 2, 2018 Share Posted February 2, 2018 Jim W., What version of Vectorworks are you using? In Vectorworks 2017, the window options look like this: There appears to be no way of changing the class of individual elements. Th Quote Link to comment
Vectorworks, Inc Employee PVA - Admin Posted February 2, 2018 Vectorworks, Inc Employee Share Posted February 2, 2018 1 hour ago, SamO said: What version of Vectorworks are you using? In Vectorworks 2017, the window options look like this: There appears to be no way of changing the class of individual elements. This looks like a localized version of the Window tool, are there other Window related tools available? My version is the English global version, but some of the distributors customize some elements or use different plugins entirely. Quote Link to comment
SamO Posted February 2, 2018 Share Posted February 2, 2018 I find the tool in the 'Architecture' toolbox, like this. Do you know of other tools that make windows? Quote Link to comment
Vectorworks, Inc Employee PVA - Admin Posted February 2, 2018 Vectorworks, Inc Employee Share Posted February 2, 2018 2 hours ago, SamO said: I find the tool in the 'Architecture' toolbox, like this. Do you know of other tools that make windows? You'll have to check with your distributor directly, I don't have any info on the localized versions here. Quote Link to comment
