HAUSrucker
VW & Reports
hi - i m a vw newbie and searching for good tutorials which teach the combination vw and database like filemaker or teach how to make reports for architectural quantity survey.
thanks
Hanns,
Do a search on the Community Board for "database", "worksheet", and/or "spreadsheet". The VW tool is called a Database Worksheet.
Most recently the following thread dealt with quantifying parts of a building model:
http://techboard.vectorworks.net/ubbthreads/ubbthreads.php?ubb=showflat&Number=114147&fpart=1
Take a look. After that, start asking questions.
What you obviously are after, is doable. If you are serious about this, you do need to have an external database system as well - and FileMaker is a very good one for this.
The trick is to make everything generic in such a manner that all data coming from VW are structured so that there is only one quantity table. This can, I believe, achieved with reports and exports of those, but it's not going to be easy.
I'm lucky. I don't use any NNA's built-in objects, only what I've created myself. I also can quantify ?drawing objects? using the same database structure. So, I may have to issue the "Quantify" command a few times, but at the end of the day, I can export a database, delete the records in the FMP database and import new data and I'm hunky dory.
