How to adjust groundcover hatch pattern scales?
Doug L
While trying to hatch groundcover areas, is there a way to globally adjust hatch pattern scales (as in AutoCAD) without having to individually edit each default hatch pattern?
Under Export PDF (batch), if I check "Export patterns at on-screen resolution", the hatch patterns are the appropriate size, but the linework is screen resolution, heavily pixelated.
If I uncheck "Export patterns at on-screen resolution", the hatch patterns are clean lines, but too dense. Needs to be enlarged 400% to be legible in the resulting PDF file.
