portamigra Posted November 24, 2008 Share Posted November 24, 2008 No matter how amazingly cool of a 3D program VW will get to be, a little 2D drafting will always be needed for some quick details. It's fun (and reads better) if you can add some character to your details and I like to add those couple of lines to make the 'ground' line appear more like ground outside. I was messing around and put the hangar tool down along my ground line, made the parameters really small, colored it green, and then covered the bottom half with a white box. The result was a pretty neat grass effect for a 2D detail. I hope this helps someone, and if you have any other ideas, lemme know! zach Quote Link to comment
gScott Posted November 24, 2008 Share Posted November 24, 2008 there is a free PIO tool that does exactly this, you draw a line, it draws a jaggy line, with parameters to customise the look .../|/\|\/\||\.... it's called "gazon" by sylvain jacquemet, VW12 or higher, at the vectordepot.com PIO site http://www.vectordepot.com/plug-ins/ Quote Link to comment
