Portmanteau Posted November 23, 2008 Share Posted November 23, 2008 (edited) Im just wondering when using the "Window Wall tool(Straight)". Are the mullions always made of glass as they appear to be in my picture: or can they be edited with another material? Edited November 23, 2008 by Portmanteau Quote Link to comment
mike m oz Posted November 23, 2008 Share Posted November 23, 2008 Window Wall objects have two Classes: - A "container Class" at the top of the OIP (and Properties) which controls the finish to the framing. - A Glazing Class towards the bottom of the OIP (and Properties) which controls the finish to the glass (Style-Glazing 1, 2 and 3). You need to apply your glass texture to the Glazing Class rather than the "container Class". Quote Link to comment
Portmanteau Posted November 24, 2008 Author Share Posted November 24, 2008 Thank you Mike but what does OIP stand for? Also is it possible to create a curved double line to represent a curved wall in a 2d Plan that can be filled with a colour with out using the wall tool which will automatically create a 3d object. Thanks for you help again & best regards, Portmanteau Quote Link to comment
mike m oz Posted November 24, 2008 Share Posted November 24, 2008 OIP = Object Info Palette. Use wall tool: - with wall height = 0; or - Convert wall to a Group and then delete unwanted parts. Quote Link to comment
Portmanteau Posted November 24, 2008 Author Share Posted November 24, 2008 Thank you so much for all of your help much appreciated. One last question I was just wondering whether if the answers to my questions can be found in any of the http://archoncad.com/hardcopy-manuals.html ? Quote Link to comment
Portmanteau Posted November 24, 2008 Author Share Posted November 24, 2008 (edited) Window Wall objects have two Classes: - A "container Class" at the top of the OIP (and Properties) which controls the finish to the framing. - A Glazing Class towards the bottom of the OIP (and Properties) which controls the finish to the glass (Style-Glazing 1, 2 and 3). You need to apply your glass texture to the Glazing Class rather than the "container Class". I still cant get the hang of it. The only place I have been able to change the materials of mullions is under the Render Tab. But the glazing always seems to stay the same. Edited November 24, 2008 by Portmanteau Quote Link to comment
Damon Design Posted November 24, 2008 Share Posted November 24, 2008 The Render tab texture selection will be the mullions. You can either just select a texture as you have done or assign it a Style associated with a texture that you have defined. The Style-Glazing # will texture will be the glazing. If you want to change the look of the glazing you need to define the Glazing style with a "Glass" texture, then customize it how you wish. You shouldn't define the Glazing styles with textures that are not glazing like, rather define them as different looks of glass-i.e. very transparent or more reflective in a file to create different looks. Quote Link to comment
Portmanteau Posted November 25, 2008 Author Share Posted November 25, 2008 (edited) The Render tab texture selection will be the mullions. You can either just select a texture as you have done or assign it a Style associated with a texture that you have defined. The Style-Glazing # will texture will be the glazing. If you want to change the look of the glazing you need to define the Glazing style with a "Glass" texture, then customize it how you wish. You shouldn't define the Glazing styles with textures that are not glazing like, rather define them as different looks of glass-i.e. very transparent or more reflective in a file to create different looks. Thank you Damon Design Could you also help with this one: How do you creat a fill for handrail 1. like handrail 2.? EDIT: Sorry its not a Handrail its a Guardrail lol Edited November 25, 2008 by Portmanteau Quote Link to comment
Damon Design Posted November 26, 2008 Share Posted November 26, 2008 Should be the same principal. Since I know of no guardrail tool (I could be wrong here) I assume you mean the top rail of the handrail PIO that you have created. Selecting the whole rail allows you to fill it, color it as you want and then all elements of that handrail PIO will have that same attribute. By creating and then defining Style attributes in your class list of your document you can then assign three different styles to the different elements of the handrail PIO Quote Link to comment
Portmanteau Posted November 26, 2008 Author Share Posted November 26, 2008 (edited) Should be the same principal. Since I know of no guardrail tool (I could be wrong here) I assume you mean the top rail of the handrail PIO that you have created. Thanks for all of your help. Edited November 26, 2008 by Portmanteau Quote Link to comment
mike m oz Posted November 26, 2008 Share Posted November 26, 2008 (edited) Portmanteau, it looks like you've discovered a bug. The selected guard colour for the Curved Guardrail shows in a 3D view, but always remains white in 2D. The Straight Guardrail behaves differently. You should submit a bug report. PS I've checked further and the same inconsistent 2D appearance behaviour still exists in VW 2009. Edited November 26, 2008 by mike m oz Quote Link to comment
Damon Design Posted November 26, 2008 Share Posted November 26, 2008 I stand corrected (well, I admitted that I could be wrong- I'm not using many road guardrails in my residential projects) but the same principles did apply; except for the bug you discovered. Thankfully this looks like one bug that won't be affecting me. Glad to help. Quote Link to comment
