red62
xforg image props
Check to make sure that all relevant classes are visible (check your class list for new classes created when inserting the xfrog props, eg: "Site-3d Trees"). HTH's
I did check classses and layers. I did notice that classes were set to grey others. I changed that to show snap modify others, all layers on and classes. I still only see a wireframe box. No image. Now all I did was insert the xfrog 3d image prop. I did not make it a plant symmbol or anything. I obviously am missing something basic. Help!
Have you tried to render the scene? 3D objects only show up as wireframe with no fill until you render the scene. Go to the View menu, Rendering and choose OpenGL as that will be the fastest render.
I did that. All I got was a grey rectangle. I have tried inserting more of the xfrog image props. The only thing I see now is a 3d locus point.
the problem i think you have is that you dont have renderworks, is that right?
from what i have seen, you need renderworks for all the 3D trees etc, you can use the 2D versions, but im sure thats not what your after.
