Morgan Pileggi Posted November 15, 2008 Share Posted November 15, 2008 i'm just starting to explore renderworks, so i am sure i am making some mistake, but i can't get multiple layers to render at the same time. for example i have my roof, walls and foundation on separate layers. i can see everything in wireframe and in shaded polygon modes, but when i try to use openGL or one of the renderworks modes everything disappears except the top layer. I've tried adding layer links but that does not seem to help. individual layers render fine if i turn the other layers off what am i missing? thanks Quote Link to comment
Vectorworks, Inc Employee Dave Donley Posted November 16, 2008 Vectorworks, Inc Employee Share Posted November 16, 2008 Hello Morgan: Is stack layers on? It's the button on the upper right of the window, to display all visible layers within a common 3D space rather than with their own views, etc. Or try a viewport with those layers in it. Viewports are a nicely-controlled environment for rendering and page layout purposes. Quote Link to comment
Morgan Pileggi Posted November 16, 2008 Author Share Posted November 16, 2008 Thanks Dave; I do not have a stack layers button, ( i'm using VW11), or at least it does not appear in the upper right. searching the help files did not turn up anything about a stack layers button, is this a later feature? anyway setting up a viewport did work, though i lost my drawing border (it is a sep. design layer). i was able to cut and paste it into the viewport. i had been doing everything with design layers and toggling visibilities to create final drawings for printing. kind of crude i know, but better then when i started using VW. i was drawing each sheet individually just using the 2d drawing tools. ( and before that it was pencils and rapidographs...) Quote Link to comment
IanH Posted November 16, 2008 Share Posted November 16, 2008 put your drawing border on a sheet layer then add your viewports to the sheet. Quote Link to comment
