Morgan Pileggi
need help with window schedules
i am having a problem with my window (and door) schedules:
i have not been able to figure out how to change the order of the windows (or doors) as they appear in the schedule. i typically number my windows sequentially (w1,w2,w3..) this works fine until i hit window#10. #10 will appear after #1, not after #9.
i run into the same thing with all my custom schedules as well.
any ideas?
thanks,
Morgan Pileggi
Engineered Solutions
i am using VW11 on a macbook pro.
Maybe someone has a better answer, but the quick work-around I use is to put a space before your numbers 1-9, and then they will order before the 10's, etc.
(i.e. " 1", " 2" etc and then "10" "11")
If you want the label to be centered in the call out bubble on the plans, you can add a space behind those numbers as well.
Unfortunately this whole thing breaks down when you get to 100
thanks, i had used a leading 0 (add 00 if you will be going over 100), maybe the space looks better, but i am still not happy with it, seems like there must be some way to gain control over the schedule order
