Morgan Pileggi Posted November 13, 2008 Share Posted November 13, 2008 i am having a problem with my window (and door) schedules: i have not been able to figure out how to change the order of the windows (or doors) as they appear in the schedule. i typically number my windows sequentially (w1,w2,w3..) this works fine until i hit window#10. #10 will appear after #1, not after #9. i run into the same thing with all my custom schedules as well. any ideas? thanks, Morgan Pileggi Engineered Solutions i am using VW11 on a macbook pro. Quote Link to comment
PB_Jake Posted November 13, 2008 Share Posted November 13, 2008 Maybe someone has a better answer, but the quick work-around I use is to put a space before your numbers 1-9, and then they will order before the 10's, etc. (i.e. " 1", " 2" etc and then "10" "11") If you want the label to be centered in the call out bubble on the plans, you can add a space behind those numbers as well. Unfortunately this whole thing breaks down when you get to 100 Quote Link to comment
Morgan Pileggi Posted November 13, 2008 Author Share Posted November 13, 2008 thanks, i had used a leading 0 (add 00 if you will be going over 100), maybe the space looks better, but i am still not happy with it, seems like there must be some way to gain control over the schedule order Quote Link to comment
Jeffrey W Ouellette Posted November 14, 2008 Share Posted November 14, 2008 Morgan, This is a known "Smart Numbering" issue. The best resolution, at this time, is to use a leading zero/zed. Quote Link to comment
