sketcher Posted November 12, 2008 Share Posted November 12, 2008 is there any way to dimensionan object, that instead of numbers, it just gives you "EQ" without changing the dimension parts in the obj info? Quote Link to comment
billtheia Posted November 12, 2008 Share Posted November 12, 2008 Not sure if this is what you're after but I simply uncheck Show Dim Value and enter "EQ" in the Leader box (and a number in the Trailer box if necessary - Like "1" for EQ1, "2" for EQ2, etc.) in the dimension's OIP. Quote Link to comment
Jonathan Pickup Posted November 12, 2008 Share Posted November 12, 2008 you can select several dimensions and do this for all of them at the same time Quote Link to comment
sketcher Posted November 12, 2008 Author Share Posted November 12, 2008 yes I knew that way, but I didnt realize I could pick several at a time... just thought there might be an easier way. Thanks Everyone! Quote Link to comment
