List classes and layers
I didn't see any way to do this with a worksheet but it would be a fairly simple VectorScript. With it you could write the names to a worksheet or text file. One other way that would require more hand work is to export the file to VectorScript, then open that text file in a wordprocessor. You can edit out the other commands to get lists of the classes and layers. Would be easier with a document with no objects.
Mike
Do you know how to create a script to do this? I am not familiar with scripts.
quote:
Mike
I was about to say that I could write the script for you in about 5 minuts, but teach a man to fish, etc. However, I got curious to see if I could write it in 5 minuts so here it is (see below). I will leave it to you to figure out how to install and run the script (see the manual). When you run it, it will ask for a file name to write the info to and allow you to put it where you want. It is a text file that can be open in any word processor or spreadsheet, or even imported into a VW worksheet.
I do encourage you and all VW users to learn to script. If you go to help in VW, you will open an html file. At the top are links to Vectorscript help: a PDF file language guide and an html function reference. Writing simple scripts like this is easy once you learn a few basic concepts.
Mike
{Script begins on next line}
procedure lycl;
var
lname, clname,ofile:string;
ci,i:integer;
obj:handle;
begin
putfile('Write Class/Layer Info to:',' ',ofile);
writeln('Classes');
ci:=classnum;
for i:= 1 to ci do
begin
clname:=classlist(i);
writeln(clname);
end;
writeln('Layers');
obj:=flayer;
while obj<>NIL do
begin
lname:=getlname(obj);
writeln(lname);
obj:=nextobj(obj);
end;
close(ofile);
end;
run(lycl);
{script ends}
Thanks a million. I will do my best to learn script. I think it would really help me on a lot of things.
Mike
procedure lycl;
var
ci,i:integer;
obj:handle;
begin
writeln('Classes');
ci:=classnum;
for i:= 1 to ci do
begin
writeln(clname);
end;
writeln('Layers');
obj:=flayer;
while obj<>NIL do
begin
writeln(lname);
obj:=nextobj(obj);
end;
close(ofile);
end;
run(lycl);
{script ends}
