grant_PD
running floorboard texture?
Could have sworn that *wood floor made a running floorboard pattern. Now it seems to not be the case. Is this so? Is there no running floorboard shader in RW?
yes...but the pattern only has an offset. Not a running pattern. How do I get the wood boards to do that?
I would like to say though, that I DO like the wood floor shader in RW. I like how one can tweek all the nuances. And while I'm happy to use the textures from elsewhere, it seems a shame that there is no running floorboard pattern. Which, to my experience, is common.
Take a look at renderworks wood textures library, at "wood flooring beech 4 small." The boards are staggered so that the seams do not line up. One can set the offset of boards in the wood floor shader, but the offset is only for one board. Then the pattern starts back at the same place. If I increase the number of boards in the shader, it merely groups the boards together into blocks.
You're right Grant, the offset can only give you something like a brick bond pattern. I will forward this as a wish to LightWorks.
