Assemblage-G Posted November 3, 2008 Share Posted November 3, 2008 [font:Arial] [/font] When using the 2D selection arrow to stretch rectangles along an axis in VW 2009 the 2D data bar shows a value for "width". However, entering a value in the data bar will not stretch the rectangle to this dimension - instead the rectangle will be stretched to wherever the cursor happens to be at the time. This also seems to be the case with ovals. Is there a way of stretching these objects using the 2D selection arrow like there is with other objects such as lines, circles, polylines etc. or is this only possible using the object properties palette? Thanks. Glenn Quote Link to comment
bonus Posted November 4, 2008 Share Posted November 4, 2008 You're right Glenn, your description is correct and this must be a bug, otherwise there would not be any data bar on rectangles and ovals. When detecting bugs you (we all) should report it a.s.a.p. to NNA by e-mail: bugsubmit@nemetschek.net All help to detect bugs is appreciated and necessary if we want them fixed. I will report this one. Quote Link to comment
Assemblage-G Posted November 4, 2008 Author Share Posted November 4, 2008 Thanks for the tip and for submitting the bug report bonus. Quote Link to comment
