bonus Posted October 31, 2008 Share Posted October 31, 2008 I have a file set to black&white only in doc pref. Still in the sheet layers some objects show in colour. Anyone clever enough....? see attached: Quote Link to comment
Bozman Posted October 31, 2008 Share Posted October 31, 2008 I believe the "Black and White" only applies to the lines, not the surface patterns. Thus, the lines are black, but the roof pattern is still whatever color/pattern you have chosen. Sometimes you can reprint from a PDF and that will convert the entire image to truly "gray-scale" which is what I think you want. Quote Link to comment
M.CH Posted October 31, 2008 Share Posted October 31, 2008 The Document preference>Black and White only should do the trick. It works for lines, fills and patterns Quote Link to comment
Pat Stanford Posted October 31, 2008 Share Posted October 31, 2008 Rendered images don't respond to the B&W preference setting. It looks like you have a viewport that is rendered in OpenGL and that is what you are seeing in color. Maybe try using the Unshaded Polygon render mode instead. Pat Quote Link to comment
bonus Posted November 1, 2008 Author Share Posted November 1, 2008 Pat, you're right, rendered objects don't respond to these settings. In a way it doesn't bother me as long as the lines are black. Surfaces in colour come out great in b/w printers anyway. It's just that it would be great to see what you get. Quote Link to comment
gmm18 Posted November 2, 2008 Share Posted November 2, 2008 You could use Viewport Class Overrides to change the color of the roof objects to white in that viewport. (As long as you have the roof class set to "Use at Creation" and the actual roof object attributes set to use class. Or, just with the PDF you already have, you can Open in Preview, do a "Save As", PDF with the Greytone Filter Option. Quote Link to comment
