Pat Stanford 1,428 Posted October 29, 2008 I have written a vectorscript that creates a worksheet showing all of the possible fields of a Plug-in in a worksheet. It includes a column showing the exact format you need to use (or copy/paste) to use the record.field in a formula. It also includes the field type so you can find those fields that should be numbers that are actually text. It is located here: http://techboard.vectorworks.net/ubbthreads/ubbthreads.php?ubb=showflat&Number=112259#Post112259 Use as you see fit. Pat Quote Share this post Link to post
gester 15 Posted February 26, 2017 is this script still available? thanks Quote Share this post Link to post
Pat Stanford 1,428 Posted February 27, 2017 Yes. All of the old Resource Share forums are now under the Archive heading. Quote Share this post Link to post
