MaxStudio
Creating Viewports using a script.
I would like to write a script that allows me to create a viewport that has predefined visibility settings.
A user should easily be able to select the type of viewport (RC Plan, P/T Plan, Construction Plan...) they want from a pulldown menu and then click create. The viewport would be created using a predefined crop that is all ready an object in the Template file.
I was able to make one using CreateVP...
something like
VAR
h=HANDLE
r=HANDLE
BEGIN
h:=CreateLayer('ASheetLayer',2);
r:=CreateVP(h);
END;
Then use SetObjectVariableInt,Bool,etc.., to set parameters 1000-1030 as you like them, avail on appendix.
Or you could use CreateDuplicateObject from one you have.
I am trying to create a Section Viewport with vectorscript and have not been able to. I have tried CreateDuplicateObject but then I cannot change the position/direction of the section.
Any ideas?
Another note on 'Section Viewports'
I am able to copy an existing 'Section Viewport' but it links to the same 'Section Line' and I cannot find that parameter to change.
I found an a subobject of viewport(122) called section viewport(509) but so far I haven't had any luck here either.
Any help in creating Section Viewports would be much appreciated.
Hi
This is a very old thread I know. But it was the best I found in Forum. Anyone have an Idea, how to create section viewport?
