RGyori Posted October 20, 2008 Share Posted October 20, 2008 I tried a forum search but couldn't find reference to this problem: Draw 2 parallel walls of the same length then use the 2D selection tool (in "unrestricted interactive scaling mode"), shift-click both walls and extend them some arbitrary distance. Screen hints indicate that both walls are being extended but in reality only one wall has been extended. Selecting/unselecting "enable connected walls mode" makes no difference. Is this normal behavior or am I missing something really, really obvious? Quote Link to comment
Pat Stanford Posted October 21, 2008 Share Posted October 21, 2008 I just checked and am seeing this behavior in both VW2008 and VW2009. One work around is to Group the walls, stretch the group and then Ungroup. Pat Quote Link to comment
bonus Posted October 21, 2008 Share Posted October 21, 2008 RGyori please submit it as a bug to: bugsubmit@nemetschek.net Quote Link to comment
M.CH Posted October 21, 2008 Share Posted October 21, 2008 Have you tried the 2d reshape mode using the selection box? Select the move handles tool then draw a selection box and move the walls the desired amount. HTH Quote Link to comment
RGyori Posted October 21, 2008 Author Share Posted October 21, 2008 Have you tried the 2d reshape mode using the selection box? Select the move handles tool then draw a selection box and move the walls the desired amount. HTH Thanks HTH. That indeed does work, though I think it would be easier to accomplish with a properly functioning 2D selection tool. I will submit it as a bug. Quote Link to comment
