bohlr Posted October 16, 2008 Share Posted October 16, 2008 Is anyone having an "out of registration" problem moving stairs in the situation described below? - Stairs between two layers - Moved using the move tool or moved a specific distance using a distance filled in the curser - Dragging the stairs does not cause the problem Problem: Stairs on the non active layer will move but will be out of registration in x,y some amount (8"-12") seem to be an inconsistent distance. Solution seems to be to go the alternate layer and move the stair back in registration with the stair on the layer on which it was originally moved. Quote Link to comment
