Pat Stanford Posted October 14, 2008 Share Posted October 14, 2008 The attached script will create a new worksheet listing the used and unused classes in a file. Copy the lines from Procedure to Run (inclusive) and paste them into a new blank Vectorscript (created from the Resource Browser). Open the script palette and double click on the script. The script automatically places the worksheet at the origin of the drawing. Use as you see fit. Pat Procedure Classes_to_Worksheet; {Make a worksheet listing all of the classes in a VW file} {Lists both used and unused classes} {The worksheet is named "Classes:"with and appended date} {October 14, 2008} {? 2008, Coviana, Inc - Pat Stanford pat@coviana.com} {Licensed under the GNU Lesser General Public License} var H1: Handle; N1: LongInt; Begin H1:=CreateWS(Concat('Classes:',date(2,1)),Classnum+2,2); For N1:= 1 to Classnum do SetWSCellFormula(H1,N1+1,1,N1+1,1,ClassList(N1)); SetWSCellFormula(H1,1,1,1,1,'Classes in File'); End; Run(Classes_to_Worksheet); Quote Link to comment
Pat Stanford Posted October 13, 2010 Author Share Posted October 13, 2010 Here is an updated version that sorts the classes alphabetically before creating the worksheet. As of VW2011 I don't think there is a way to get the display order of the classes in the Navigation Palette. Procedure Classes_to_Worksheet; {Make a worksheet listing all of the classes in a VW file} {Lists both used and unused classes} {The worksheet is named "Classes:"with and appended date} {October 13, 2010} {Updated to sort classes in alphabetical order prior to storing in worksheet} {As of VW2011, there is not way to get the display order of the classes in the Nav Palette} {October 14, 2008} {? 2010, 2008, Coviana, Inc - Pat Stanford pat@coviana.com} {Licensed under the GNU Lesser General Public License} var H1: Handle; N1: LongInt; ClassSort : Array[1..1024] of string; Begin H1:=CreateWS(Concat('Classes:',date(2,1)),Classnum+2,2); For N1:= 1 to Classnum do ClassSort[N1]:=ClassList(N1); SortArray(ClassSort,ClassNum,1); For N1:= 1 to Classnum do SetWSCellFormula(H1,N1+1,1,N1+1,1,ClassSort[N1]); SetWSCellFormula(H1,1,1,1,1,'Classes in File'); End; Run(Classes_to_Worksheet); 1 Quote Link to comment
SCParker Posted October 14, 2010 Share Posted October 14, 2010 Pat, This is a great help. One of the hard parts of the power of classes is remembering what we have. I don't know how many times I've created a new class for an object just to find later that I should have placed it in an existing class. Thanks, Scott Quote Link to comment
TimG Posted December 2, 2014 Share Posted December 2, 2014 (edited) Nevermind... i didn't see any other reply's due to my forum settings, I see you updated the script for alphabetical... I'll give that a try. sorry I got this script to work, Thanks... However, is there a way I can get it to list in a worksheet alphabetically? When I run the script as us above, I think it maybe listing them in the worksheet by the order they were created in? Edited December 2, 2014 by TimG Quote Link to comment
Pat Stanford Posted April 11, 2015 Author Share Posted April 11, 2015 OK, I updated this again. This one is kind of nifty. It goes through and makes a list of all the Classes (used and unused) in a file along with the number of objects in that class. Just like before, but with better formatting. The Nifty part is that I have added some database integration. After you run the script to create the worksheet, if you change any of the yellow cells in column A from blank to anything (try typing an X), a related database row at the bottom of the worksheet will open showing subrows for every object in the class. Each subrow will show the Class, Layer and Object type. Like with any other database, you can right-click on the sub-row row header (i.e. 40.7) and SELECT that item in the drawing and change views so it is visible. Please note that this is a fairly slow script and worksheet. It takes about 25 seconds on my 2008 MacBook Pro to run on a file with about 50 classes and 1300 objects. It has to make a separate database for each class and every object in the drawing will be included in one of those databases. Use at your own risk. Procedure Classes_to_Worksheet; {Make a worksheet listing all of the classes in a VW file} {Lists both used and unused classes} {The worksheet is named "Classes:"with and appended date} {April 10, 2015} {Updated for formatting and to add database integration} {Set any of the yellow cells in column 1 to non-blank and the related} {database row at the bottom of the worksheet will show subrows for each item in that class} {Set the yellow cell back to blank (select, delete, enter/return, and the database subrows} {will disapper. The database rows show the Class, Layer and Object type for the related object} {October 13, 2010} {Updated to sort classes in alphabetical order prior to storing in worksheet} {As of VW2011, there is not way to get the display order of the classes in the Nav Palette} {October 14, 2008} {? 2010, 2008, Coviana, Inc - Pat Stanford pat@coviana.com} {Licensed under the GNU Lesser General Public License} var H1, H2: Handle; N1: LongInt; ClassSort : Array[1..1024] of string; Formula : String; Result : Boolean; Font,Size,Style:Integer; Begin SetCursor(WatchC); H1:=CreateWS(Concat('Classes:',date(2,1)),(Classnum+2)*2,4); SetWSCellAlignment(H1,1,1,ClassNum+2,2,5); SetWSColumnWidth(H1,1,1,20); SetWSColumnWidth(H1,2,2,200); SetWSColumnWidth(H1,3,3,200); SetWSColumnWidth(H1,4,4,200); Result := WorksheetMergeCells(H1,1,1,1,3); GetWSCellTextFormat(H1,1,1,Font,Size,Style); SetWSCellTextFormat(H1,1,1,(ClassNum+2)*2,4,Font,14,Style); SetWSCellTextFormat(H1,1,1,1,1,Font,18,1); SetWSCellTextFormat(H1,2,1,2,4,Font,14,1); SetWSCellTextFormat(H1,Classnum+4,1,ClassNum+4,4,Font,14,1); SetWSCellBorders(H1,3,1,ClassNum+2,3,True,True,True,True,7); SetWSCellOutlineBorder(H1,3,1,ClassNum+2,3,2,25,1); SetWSCellBorders(H1,Classnum+5,1,(ClassNum+2)*2,4,True,True,True,True,7); SetWSCellOutlineBorder(H1,Classnum+5,1,(ClassNum+2)*2,4,2,25,1); SetWSCellFill(H1,3,1,ClassNum+2,1,1,5,0,1); SetWSCellFill(H1,ClassNum+5,1,(ClassNum+2)*2,1,1,1,0,1); For N1:= 1 to Classnum do ClassSort[N1]:=ClassList(N1); SortArray(ClassSort,ClassNum,1); For N1:= 1 to Classnum do Begin SetWSCellNumberFormat(H1,N1+2,2,N1+2,2,13,0,'',''); SetWSCellFormula(H1,N1+2,2,N1+2,2,Concat(ClassSort[N1])); Formula:=Concat('=Count(C=',CHR(39),Classsort[N1],CHR(39),')'); SetWSCellFormula(H1,N1+2,3,N1+2,3,Formula); Formula:=Concat('=Database(C=IF(A',Num2Str(0,N1+2),'<>',CHR(39),CHR(39),', B',Num2Str(0,N1+2),',',CHR(39),'PTS!@#$%^&',CHR(39),'))'); SetWSCellFormula(H1,ClassNum+4,2,ClassNum+4,2,'Class'); SetWSCellFormula(H1,ClassNum+4,3,ClassNum+4,3,'Layer'); SetWSCellFormula(H1,ClassNum+4,4,ClassNum+4,4,'Object Type'); SetWSCellFormula(H1,N1+ClassNum+4,0,N1+ClassNum+4,0,Formula); SetWSCellFormula(H1,N1+ClassNum+4,2,N1+ClassNum+4,2,'=C'); SetWSCellFormula(H1,N1+ClassNum+4,3,N1+ClassNum+4,3,'=L'); SetWSCellFormula(H1,N1+ClassNum+4,4,N1+ClassNum+4,4,'=T'); Message('Number of Classes Processes: ',N1); Wait(1); End; SetWSCellFormula(H1,1,1,1,1,Concat('Classes in File:',date(2,1))); SetWSCellFormula(H1,2,2,2,2,'Class Name'); SetWSCellFormula(H1,2,3,2,3,'# of Objects in Class'); RecalculateWS(H1); SetCursor(ArrowC); ClrMessage; ShowWS(H1,True); End; Run(Classes_to_Worksheet); 2 Quote Link to comment
michaelk Posted April 11, 2015 Share Posted April 11, 2015 Pat This is really cool. Thanks! MK Quote Link to comment
Pat Stanford Posted April 11, 2015 Author Share Posted April 11, 2015 I thought you would like it Michael. I didn't know that you could use an IF statement in a database definition until I tried it yesterday. Quote Link to comment
michaelk Posted April 11, 2015 Share Posted April 11, 2015 Every time I take over a drawing from someone else I have a similar worksheet called "Find Crazy Things" that I modify manually to track down objects in a '0' class or find all the windows and doors that are in a DTM-Modifer class. I'm going to have to take your script apart. I think I get how you did it. Except for PTS!@#$%^&. What's up with that? mk Quote Link to comment
Pat Stanford Posted April 12, 2015 Author Share Posted April 12, 2015 I wanted a "Class Name" that was unlikely to ever be used in an actual file. I figured that if someone used that string as an actual class name there would already be cursing enough that it might be funny to see that displayed for every one of the database lines. But probably not. Quote Link to comment
Pat Stanford Posted April 12, 2015 Author Share Posted April 12, 2015 It is probably easier to figure out how this all works from the worksheet than from the script. In the worksheet I just used the script to create a single database line for each class using a formula similar to: =database(If(A5<>'',C=B5,C='Name never to be used by a real class')) The trick in the script is to use CHR(39) to generate the single quotes needed as delimiters in the formula. Quote Link to comment
grant_PD Posted April 14, 2015 Share Posted April 14, 2015 it seems to be working now. Thanks. I'll let you know how it goes. Quote Link to comment
ibenjamin.price Posted November 8, 2016 Share Posted November 8, 2016 Nice one Pat! Thanks for posting. This is super helpful. Quote Link to comment
bcd Posted November 9, 2016 Share Posted November 9, 2016 Interesting concept Pat - Very nice work. I could see the concept that underlies this worksheet being incorporated into the Navigation Palette; a Nav+ so to speak. Quote Link to comment
lgoodkind Posted November 2, 2020 Share Posted November 2, 2020 (edited) Pat. Wondered if you have a quick way to list all classes in a worksheet? Or point me to where I can learn more about doing so? Nevermind - I was able to figure it out. Edited November 2, 2020 by lgoodkind Quote Link to comment
Elite Exhibits Posted December 20, 2022 Share Posted December 20, 2022 On 4/10/2015 at 10:18 PM, Pat Stanford said: OK, I updated this again. This one is kind of nifty. It goes through and makes a list of all the Classes (used and unused) in a file along with the number of objects in that class. Just like before, but with better formatting. The Nifty part is that I have added some database integration. After you run the script to create the worksheet, if you change any of the yellow cells in column A from blank to anything (try typing an X), a related database row at the bottom of the worksheet will open showing subrows for every object in the class. Each subrow will show the Class, Layer and Object type. Like with any other database, you can right-click on the sub-row row header (i.e. 40.7) and SELECT that item in the drawing and change views so it is visible. Please note that this is a fairly slow script and worksheet. It takes about 25 seconds on my 2008 MacBook Pro to run on a file with about 50 classes and 1300 objects. It has to make a separate database for each class and every object in the drawing will be included in one of those databases. Use at your own risk. Procedure Classes_to_Worksheet; {Make a worksheet listing all of the classes in a VW file} {Lists both used and unused classes} {The worksheet is named "Classes:"with and appended date} {April 10, 2015} {Updated for formatting and to add database integration} {Set any of the yellow cells in column 1 to non-blank and the related} {database row at the bottom of the worksheet will show subrows for each item in that class} {Set the yellow cell back to blank (select, delete, enter/return, and the database subrows} {will disapper. The database rows show the Class, Layer and Object type for the related object} {October 13, 2010} {Updated to sort classes in alphabetical order prior to storing in worksheet} {As of VW2011, there is not way to get the display order of the classes in the Nav Palette} {October 14, 2008} {? 2010, 2008, Coviana, Inc - Pat Stanford pat@coviana.com} {Licensed under the GNU Lesser General Public License} var H1, H2: Handle; N1: LongInt; ClassSort : Array[1..1024] of string; Formula : String; Result : Boolean; Font,Size,Style:Integer; Begin SetCursor(WatchC); H1:=CreateWS(Concat('Classes:',date(2,1)),(Classnum+2)*2,4); SetWSCellAlignment(H1,1,1,ClassNum+2,2,5); SetWSColumnWidth(H1,1,1,20); SetWSColumnWidth(H1,2,2,200); SetWSColumnWidth(H1,3,3,200); SetWSColumnWidth(H1,4,4,200); Result := WorksheetMergeCells(H1,1,1,1,3); GetWSCellTextFormat(H1,1,1,Font,Size,Style); SetWSCellTextFormat(H1,1,1,(ClassNum+2)*2,4,Font,14,Style); SetWSCellTextFormat(H1,1,1,1,1,Font,18,1); SetWSCellTextFormat(H1,2,1,2,4,Font,14,1); SetWSCellTextFormat(H1,Classnum+4,1,ClassNum+4,4,Font,14,1); SetWSCellBorders(H1,3,1,ClassNum+2,3,True,True,True,True,7); SetWSCellOutlineBorder(H1,3,1,ClassNum+2,3,2,25,1); SetWSCellBorders(H1,Classnum+5,1,(ClassNum+2)*2,4,True,True,True,True,7); SetWSCellOutlineBorder(H1,Classnum+5,1,(ClassNum+2)*2,4,2,25,1); SetWSCellFill(H1,3,1,ClassNum+2,1,1,5,0,1); SetWSCellFill(H1,ClassNum+5,1,(ClassNum+2)*2,1,1,1,0,1); For N1:= 1 to Classnum do ClassSort[N1]:=ClassList(N1); SortArray(ClassSort,ClassNum,1); For N1:= 1 to Classnum do Begin SetWSCellNumberFormat(H1,N1+2,2,N1+2,2,13,0,'',''); SetWSCellFormula(H1,N1+2,2,N1+2,2,Concat(ClassSort[N1])); Formula:=Concat('=Count(C=',CHR(39),Classsort[N1],CHR(39),')'); SetWSCellFormula(H1,N1+2,3,N1+2,3,Formula); Formula:=Concat('=Database(C=IF(A',Num2Str(0,N1+2),'<>',CHR(39),CHR(39),', B',Num2Str(0,N1+2),',',CHR(39),'PTS!@#$%^&',CHR(39),'))'); SetWSCellFormula(H1,ClassNum+4,2,ClassNum+4,2,'Class'); SetWSCellFormula(H1,ClassNum+4,3,ClassNum+4,3,'Layer'); SetWSCellFormula(H1,ClassNum+4,4,ClassNum+4,4,'Object Type'); SetWSCellFormula(H1,N1+ClassNum+4,0,N1+ClassNum+4,0,Formula); SetWSCellFormula(H1,N1+ClassNum+4,2,N1+ClassNum+4,2,'=C'); SetWSCellFormula(H1,N1+ClassNum+4,3,N1+ClassNum+4,3,'=L'); SetWSCellFormula(H1,N1+ClassNum+4,4,N1+ClassNum+4,4,'=T'); Message('Number of Classes Processes: ',N1); Wait(1); End; SetWSCellFormula(H1,1,1,1,1,Concat('Classes in File:',date(2,1))); SetWSCellFormula(H1,2,2,2,2,'Class Name'); SetWSCellFormula(H1,2,3,2,3,'# of Objects in Class'); RecalculateWS(H1); SetCursor(ArrowC); ClrMessage; ShowWS(H1,True); End; Run(Classes_to_Worksheet); Pat Is there a version of the script that works in 2020 - 2023 ? Appreciated Peter Quote Link to comment
Pat Stanford Posted December 20, 2022 Author Share Posted December 20, 2022 I thought I had already posted this, but here is the version that was modified for VW2019. In a very quick test it appeared to work fine in VW2023. HTH. Procedure Classes_to_Worksheet; {Make a worksheet listing all of the classes in a VW file} {Lists both used and unused classes} {The worksheet is named "Classes:"with and appended date} {April 12, 2019} {Modified to work around obsolete VS functions for formatting Worksheets} {Yellow check mark cells to select classes to detail are now formatted as text so data will execute.} {Datbase Headers are now turned off this can be changed in the SetObjectVariable Boolean (82) line.} {January 26, 2017} {Added code to display the Class Fill color in the ClassName column for the Class} {April 10, 2015} {Updated for formatting and to add database integration} {Set any of the yellow cells in column 1 to non-blank and the related} {database row at the bottom of the worksheet will show subrows for each item in that class} {Set the yellow cell back to blank (select, delete, enter/return, and the database subrows} {will disapper. The database rows show the Class, Layer and Object type for the related object} {October 13, 2010} {Updated to sort classes in alphabetical order prior to storing in worksheet} {As of VW2011, there is not way to get the display order of the classes in the Nav Palette} {October 14, 2008} {© 2019, 2017, 2010, 2008, Coviana, Inc - Pat Stanford pat@coviana.com} {Licensed under the GNU Lesser General Public License} var H1, H2: Handle; N1: LongInt; ClassSort : Array[1..1024] of string; Formula : String; Result : Boolean; Font,Size,Style:Integer; R1,G1,B1,BGColor,FGColor: LongInt; FillPattern: Integer; Begin SetCursor(WatchC); H1:=CreateWS(Concat('Classes:',date(2,1)),(Classnum+2)*2,4); SetWSCellAlignment(H1,1,1,ClassNum+2,2,5); SetWSColumnWidth(H1,1,1,20); SetWSColumnWidth(H1,2,2,200); SetWSColumnWidth(H1,3,3,200); SetWSColumnWidth(H1,4,4,200); Result := WorksheetMergeCells(H1,1,1,1,3); GetWSCellTextFormat(H1,1,1,Font,Size,Style); SetWSCellTextFormat(H1,1,1,(ClassNum+2)*2,4,Font,14,Style); SetWSCellTextFormat(H1,1,1,1,1,Font,18,1); SetWSCellTextFormat(H1,2,1,2,4,Font,14,1); SetWSCellTextFormat(H1,Classnum+4,1,ClassNum+4,4,Font,14,1); SetWSCellBorders(H1,3,1,ClassNum+2,3,True,True,True,True,7); {SetWSCellOutlineBorder(H1,3,1,ClassNum+2,3,2,25,1); (*Commented out 4/12/19 Decprecated*) }SetWSCellBorders(H1,Classnum+5,1,(ClassNum+2)*2,4,True,True,True,True,7); {SetWSCellOutlineBorder(H1,Classnum+5,1,(ClassNum+2)*2,4,2,25,1); (*Commented out 4/12/19 Decprecated*) } SetWSCellFill(H1,3,1,ClassNum+2,1,1,5,0,1); SetWSCellFill(H1,ClassNum+5,1,(ClassNum+2)*2,1,1,1,0,1); For N1:= 1 to Classnum do ClassSort[N1]:=ClassList(N1); SortArray(ClassSort,ClassNum,1); For N1:= 1 to Classnum do Begin {*****************************} {Code in this block is used to set the WS Cell Format to match the Class Fill Color and Pattern} GetClFillFore(ClassSort[N1],R1,G1,B1); RGBToColorIndex(R1,G1,B1,FGColor); GetClFillBack(ClassSort[N1],R1,G1,B1); RGBToColorIndex(R1,G1,B1,BGColor); FillPattern:=GetClFPat(ClassSort[N1]); SetWSCellFill(H1,N1+2,2,N1+2,2,1,BGColor,FGColor,FillPattern); SetWSCellNumberFormat(H1,N1+2,1,N1+2,1,13,0,'',''); {Added 4/12/2019 Format cells as text} {This code can be deleted or commented out without effecting other script functionality} {*****************************} SetWSCellNumberFormat(H1,N1+2,2,N1+2,2,13,0,'',''); SetWSCellFormula(H1,N1+2,2,N1+2,2,Concat(ClassSort[N1])); Formula:=Concat('=Count(C=',CHR(39),Classsort[N1],CHR(39),')'); SetWSCellFormula(H1,N1+2,3,N1+2,3,Formula); Formula:=Concat('=Database(C=(IF(A',Num2Str(0,N1+2),'<>',CHR(39),CHR(39), ', B',Num2Str(0,N1+2),',',CHR(39),'PTS!@#$%^&',CHR(39),')))'); SetWSCellFormula(H1,ClassNum+4,2,ClassNum+4,2,'Class'); SetWSCellFormula(H1,ClassNum+4,3,ClassNum+4,3,'Layer'); SetWSCellFormula(H1,ClassNum+4,4,ClassNum+4,4,'Object Type'); SetWSCellFormula(H1,N1+ClassNum+4,0,N1+ClassNum+4,0,Formula); SetWSCellFormula(H1,N1+ClassNum+4,2,N1+ClassNum+4,2,'=C'); SetWSCellFormula(H1,N1+ClassNum+4,3,N1+ClassNum+4,3,'=L'); SetWSCellFormula(H1,N1+ClassNum+4,4,N1+ClassNum+4,4,'=T'); SetWSCellNumberFormat(H1,N1+2,2,N1+2,2,13,0,'',''); {Added 4/12/2019 Format cells as text} End; SetWSCellFormula(H1,1,1,1,1,Concat('Classes in File:',date(2,1))); SetWSCellFormula(H1,2,2,2,2,'Class Name'); SetWSCellFormula(H1,2,3,2,3,'# of Objects in Class'); RecalculateWS(H1); SetCursor(ArrowC); ClrMessage; ShowWS(H1,True); SetObjectVariableBoolean(H1,82,False); {Added 4/12/19 to hide database header rows.} End; Run(Classes_to_Worksheet); 2 Quote Link to comment
Elite Exhibits Posted December 21, 2022 Share Posted December 21, 2022 Pat I am most grateful Peter Quote Link to comment
Pat Stanford Posted December 21, 2022 Author Share Posted December 21, 2022 You are very welcome. You know about the magic trick that this worksheet does right? 😉 Quote Link to comment
Elite Exhibits Posted December 22, 2022 Share Posted December 22, 2022 On 4/10/2015 at 10:18 PM, Pat Stanford said: The Nifty part is that I have added some database integration. After you run the script to create the worksheet, if you change any of the yellow cells in column A from blank to anything (try typing an X), a related database row at the bottom of the worksheet will open showing subrows for every object in the class. Each subrow will show the Class, Layer and Object type. Like with any other database, you can right-click on the sub-row row header (i.e. 40.7) and SELECT that item in the drawing and change views so it is visible. Pat ¿ You are reference the database option ? Let Me Know ... Peter Quote Link to comment
Elite Exhibits Posted December 22, 2022 Share Posted December 22, 2022 Pat Please and Thank You email me a current postal address and I send you a token of my thanks for your efforts Peter Quote Link to comment
Pat Stanford Posted December 22, 2022 Author Share Posted December 22, 2022 1 hour ago, Elite Exhibits said: ¿ You are reference the database option ? Yes, I think the ability to get the sublist in a single worksheet instead of having to edit criteria of have multiple worksheets is kind of neat. I'm glad I thought to try the criteria that made it work. Pat 1 Quote Link to comment
hollister design Studio Posted January 31, 2024 Share Posted January 31, 2024 @Pat Stanford Thanks for the link to this from the Custom Classes post! Quick question, what is determining the background color in the "B" column? It doesn't seem to be the class fill of line color... See below - '00-NOTE' is purple in the worksheet - but when selected it shows fill color to be white. Quote Link to comment
Pat Stanford Posted January 31, 2024 Author Share Posted January 31, 2024 I just tested in a simple file and for me it is providing the Fill Background Color. Can you DM me a file that I can take a look at an see what is going on? Quote Link to comment
