StephenA Posted March 20, 2001 Share Posted March 20, 2001 I sent an eps file to my printing firm to be printed in color. the image looked great except the worksheets I had on the drawing did not appear on the print. These were legends - essential! help! Quote Link to comment
MikeB Posted March 21, 2001 Share Posted March 21, 2001 I would suggest using a postscrip file instead. I've seen some posts stating that the eps export option in VW can be a little buggy. good Luck Quote Link to comment
PeterT Posted March 22, 2001 Share Posted March 22, 2001 If you're on a Mac, prior to the export, cut the worksheet from the drawing, paste it into the Scrapbook (in the apple menu), now cut it from the Scrapbook and paste it back in your drawing. It will come in as simple lines and regular text. Now it should export like any other object. I think this process works also if you do the intermediate paste into any graphics application instead of the scrapbook which may also work on the Windows platform. A bit of a work around, but should work. Regards, PeterT Quote Link to comment
