RubenH Posted October 6, 2008 Share Posted October 6, 2008 (edited) Has a database Foundation? Is the adoption of vwx extension about xml or other kind of technology? If yes, what implies? Maybe someone (maybe NNA), can bring light on those themes. These arguments are important to the understanding of Bim in Vw. Thanks in advance Edited October 7, 2008 by Mr. Gog Quote Link to comment
Cris with no H Posted October 7, 2008 Share Posted October 7, 2008 The extension name change is a reflection of the fact that we're no longer called MiniCAD (which is where .mcd comes from). File format changes, which happen at every major version release, are necessary due to improved capabilities and the need to hold data about objects that use those capabilities. For instance, VW10 has no idea what sheet layers are, VW11 has no clue about layer transparency, VW12 can't do object transparency, etc etc. Cris Dopher Quote Link to comment
RubenH Posted October 7, 2008 Author Share Posted October 7, 2008 (edited) I asked about the extension becouse of IFC. IfcXML is supported in Vw. I Think that the "X" in the extension is related to the ifcXML specification. Edited October 7, 2008 by Mr. Gog Quote Link to comment
RubenH Posted October 8, 2008 Author Share Posted October 8, 2008 (edited) From Architosh. Interview with Dr. Biplab Sarkar: AFR: Last question. Your integration of FileMaker into Landmark is very elegant. It's beautiful. Why not work with a third-party FileMaker developer to tackle the cost estimation application? That way you don't have to go out and build cost estimation yourself? BS: That could be one way to do it. But we are looking at XML and the types of tools that have been built exchanging data via XML. AFR: Thank you Biplab Sarkar for talking to me. Edited October 8, 2008 by Mr. Gog Quote Link to comment
Christiaan Posted October 8, 2008 Share Posted October 8, 2008 My assumption was the x simply relates to the sound of saying Vectorworks. Quote Link to comment
RubenH Posted October 8, 2008 Author Share Posted October 8, 2008 Maybe, maybe. =) Quote Link to comment
Jeffrey W Ouellette Posted October 10, 2008 Share Posted October 10, 2008 Wow, Leave you guys alone for a few days and you come up with some real doozies... . Rub?n, VWX is just an reflection/alliteration? of Vectorworks. Please don't read too much into it. XML is a file format that VW uses to store preference files. More research is needed to understand using XML schemas to exchange relevant BIM/CADD/file data. XML schemas are NOT universal or interchangable. gbXML is NOT the same as ifcXML. They use the same syntax, but not the same content. Quote Link to comment
RubenH Posted October 10, 2008 Author Share Posted October 10, 2008 Jeffrey, don't leave us alone, we can get real crazy :crazy: and produce "real unique" situations here... But what about the first question: Does Vw has a database foundation? Thanks... Quote Link to comment
Jeffrey W Ouellette Posted October 10, 2008 Share Posted October 10, 2008 Rub?n, Not to sound dense, but what exactly do you mean? Aren't all file formats essentially databases? Many of them are proprietary and deal with lists of information/data in their own way. I'm not sure I understand what you're trying to get at. Quote Link to comment
RubenH Posted October 10, 2008 Author Share Posted October 10, 2008 Rub?n, Aren't all file formats essentially databases? Many of them are proprietary and deal with lists of information/data in their own way. That's what I understand. Jeffrey: Sometimes I talk to individuals that uses revit or another Bim application. They talk about the lack of a database foundation inside Vw. An official argument in response to those users that are misinforming about the reality of Vectorworks, is really appreciated. That's why I asked... Sorry if you misunderstood, my english is not to good. Quote Link to comment
Jeffrey W Ouellette Posted October 11, 2008 Share Posted October 11, 2008 (edited) Rub?n, When someone from another competitor's perspective asks such a question, the answer should be that VW has the ability to generate reports on any and all elements within the file by using the database worksheet functionality. To our users, this is functionality is embodied in the "Create Reports" and "VA Create Schedule" commands. The user is able to create linked database worksheets which parse the data elements in the file as desired by the user (e.g. Door Schedule, Window Schedule). These schedules/database worksheets can be customized by the user to a very high degree. In some cases, the schedules/database worksheets are bi-directional, allowing the user to change values in the cell of the worksheet and have it change the respective parameters of the object in the file (e.g. doors and Door Schedules). I can create database worksheets that count walls, their areas, heights, thicknesses, etc. Truth is, VW has been doing that longer than Autodesk has owned Revit and maybe even longer than Revit has been around. Database worksheet functionality was introduced in 1991 with MiniCAD+ 3. Edited October 11, 2008 by Jeffrey W Ouellette Quote Link to comment
RubenH Posted October 11, 2008 Author Share Posted October 11, 2008 Thanks Jeffrey... Now I fell secure to tell what I already understood, but wasn't sure enough! Quote Link to comment
