Artlantis Interface
carpalmer
succesfully exported model to Artlantis 2, but its bundled some parts together, so that when I apply grass to the garden, it applies it to my walls too!
I imagine I need to do some eadjustments to the model in Vectorworks? Different classes? Also, how do I make those adjustments and then update my Artlantis model? I've read there's an aotomatic update...
thx
carpalmer
VW 2008 / XP
What I do is to export to Artlantis studio using 3ds (simple object) with different classes and assigned textures in each class ..... works out basically OK .... you still have to assign materiales .... some classes merge together because of line an fill color matches so try and use different colors ... good luck!
Why do you export to 3ds Don, when there's a plugin that exports directly to artlantis format?
carpalmer, first of all make sure you're using the Artlantis/VW export plugin from the the Alnatis website.
Then make sure you're exporting by Class and give each separate material a separate Class. To update an existing model simply use the update option when exporting and then choose your existng artlantis file to update it.
*RANT* So I went to see this new(to me) product via the link post here.
You need to create an account to download a demo, thus I complied. Got the mail to verify the account, BUT my login or Password is incorrect eventhough I copy/paste out of the 'Password request' mail. *RANT* :mad:
Edited by cad@sggsa
Just tried to create a new account, clicked on the email link and got this response when I tried to log in:
"This account is already active. This user account doesn't exist.
Please contact Abvent or return to the login page"
Anyone care to translate?
Well, I clicked on: "return to the login page" and I'm logged in.
Very strange!
Edited by G_Hannigan
Artlantis Plugins:
There are specific VectorWorks plugins which are put into VW workspaces.
If you are running 12.5.1/2/3 you can run Artlantis 1.2
With 2008/9 you can run Artlantis 1.2 or 2.0, which is the current edition.
What is available for download is 2.0 so you need 2008 to demo with.
Your alternative is importing dxf/dwg or 3DS files into Artlantis.
HTH
  • 3 weeks later...
I have now seem to find the problem here.
In the validation mail they send you there is a link to a page...
This Page has a blue "i" info icon that does not work or act like the same ones found on the site. I take it that it would open another page and thus activate the account. :mad: :confused: :cry:
Sorry Christiaan ...... I've been away ....
I can't use the plugin because I can't use stack layers (the way I work) to export... all the layers get set to ground level in the artlantis model.... (which is really annoying) the only way I can export the model properly is 3ds .... but I lose all class references and the model gets separate ayers through the textures I assign to each class in VW.
Unless there?s a setting for VW to export maintaining layer heights etc...??
Is There?? .... I've looked everywhere but found nothing...
  • 4 weeks later...
donm,
if you're using 12.5 or below:
make a new layer, active only + 'layer link' all the
relevant layers, with the 'show 2d' option OFF.
make sure that 'stack layers' is turned OFF
use either class or material
mapping in VW to set the parts that will
receive artlantis materials.
export to artlantis with the update option,
so that you don't lose your artlantis materials,
cameras + lighting.
BTW, the '2008' plugin from artlantis, that
gives you the choice of artlantis 1.2 or 2.0,
ALSO works with VW 12.5.3
