3d Polygon, reduce vertices?
CRSA_890
We have a site model that was created with a series of 3d polygons, that have a TON of vertices. Rendering time is ridiculous, due to the many polys that create the site model, and even wireframe is crazy. VW 12.5.3 (do not laugh, it works)
Am I stuck recreating the 3d Polys with many fewer vertices?
I know I can modify the poly and delete some, but I am hoping for a nice easy command to distribute, or lessen the vertices in the polys.
I tried using the site model option where you can insert a 'Smoothing Interval' but since all the vertices are original, it will not remove any.
Any thoughts on how to keep this a simple task?
Thanks,
Spinner
  • 3 months later...
