Maryhill Matt Posted September 24, 2008 Share Posted September 24, 2008 (edited) I regularly recieve drawings from an OS mapping company, now the drawing has been brought into vectorworks but it still has all of its (there) Classes. I was wondering if there was a way in which i could import the drawing so as the Classes on there drawing would update to the classes on my drawing. For example > Class G80121009 > Roads. << My layer I am just wondering if there is a way to automate the process rather than going in and renaming 400 layers? Thanks in advance for anyone who could point me in the right direction. Matt Edited September 24, 2008 by Maryhill Matt Quote Link to comment
CipesDesign Posted September 24, 2008 Share Posted September 24, 2008 During the DWG File Import process you can choose to place a "prefix-" on to all imported DWG Layers (which become VW's classes). It doesn't exactly rename them, but at least it allows you to easily segregate them from other classes. I have attached a screenshot of the appropriate dialog: Quote Link to comment
atari2600 Posted September 24, 2008 Share Posted September 24, 2008 The most automated way I have found is to use the "Class and Layer Mapping" tool. It takes some getting used to, and you can save your results to a .txt file for future recall. Another way is to highlight several classes you wish to "merge" into one of your existing classes, and simply right click & delete them. You will get prompted as to what to do with the objects on the classes you are deleting. One of the options is to reassign them to another class. hope this helps. Matt Quote Link to comment
Jeffrey W Ouellette Posted September 24, 2008 Share Posted September 24, 2008 Matt, With VW2008 & 2009, the other option is to simply import the AutoCAD file, as is, as a separate "reference" file, then create a DLVP in your desired project document to point to this AutoCAD "reference" file. That way none of the AutoCAD layer/class names are imported, you can draw over the top of them as needed and if the info changes, you simple re-import the AutoCAD data into the "reference" file, save and update the project file reference link. Quote Link to comment
Maryhill Matt Posted September 25, 2008 Author Share Posted September 25, 2008 Thanks for your answers there people, the thing i was looking for was the class and layer mapping. Thanks to you all, i will try and use my guidance to help you if needed in the future. Matt Quote Link to comment
Jonathan Pickup Posted September 25, 2008 Share Posted September 25, 2008 class and layer mapping will do this. i covered the class and layer mapping in my online user group a few months ago: http://www.archoncad.co.nz/usergroup/join_int.php Quote Link to comment
Maryhill Matt Posted September 26, 2008 Author Share Posted September 26, 2008 Thanks mate. I have now sorted out what i have to do in order to merge the OS layers with my own, but when i go to save the Class Mapping file it saves it as a .txt file, then when i go to try and load the file in a new drawing it says "this is not a CLASS mapping style" What is it that i am doing wrong? Matt Quote Link to comment
