CS1 Posted September 17, 2008 Share Posted September 17, 2008 (edited) I think my computer specs are reasonable (shown below in signature) however when ever I create a site model my machine becomes extremely sluggish, I have no problems with any other programs (nor games ) which have intense graphics. I have attached the OIP info of the site model to hopefully give an indication on size and complexity. Edited September 17, 2008 by CS1 Quote Link to comment
islandmon Posted September 18, 2008 Share Posted September 18, 2008 Just a thought ... Site Models are processor intensive and may require paging out to Virtual Memory partition .. especially on XP ... this process can really slow things down. Quote Link to comment
monkey Posted September 18, 2008 Share Posted September 18, 2008 i have found exactly the same problem when creating site models. the bigger the site the slower the machine is to reacting to the changes you make. One excellent tip i found was using a site boundary to get rid of any bits of the site model you do not need, simply copy your site boundary, select your site model, then go to 'edit group' in the modify menu and paste your site boundary in place, then exit and update your site model, now you should only be left with the area you need. this tends to speed things up a little if you are dealing with a large site. Quote Link to comment
CipesDesign Posted September 18, 2008 Share Posted September 18, 2008 Another tip: if your Site Model is polygon-based (that is, made from 3d polys), try this. After converting the 2d polys to 3d contours and before running the "Create Site Model" command, select all polys and run the "filter 3d polys..." command. I usually can get away with reducing down to a 12" interval which will reduce the vertex count of each poly dramatically. This will speed up the Site Model. Of course it won't be quite as accurate, but usually still accurate enough for my purposes. Quote Link to comment
Bob Holtzmann Posted September 19, 2008 Share Posted September 19, 2008 Interesting... I don't have a "Filter 3D Polys" command, but then again I don't have the Designer version of VW2008. Instead, I use the "Purge Polygons" command from VectorBits, which I use on 2D poly contours before I convert them to 3D polys. I also found a bar mode of the 2D reshape tool where you can point click to delete vertices - much faster than the Obj Info Palette. And you're right, Peter. The Create Site Model and Update commands are really sped up by simplifying the contour polys. Quote Link to comment
CS1 Posted September 21, 2008 Author Share Posted September 21, 2008 I use 3D loci to generate my site model, is there a way to simplify this? Quote Link to comment
CipesDesign Posted September 21, 2008 Share Posted September 21, 2008 Not sure. Robert? EJ? Anyone? Quote Link to comment
Robert Anderson Posted September 22, 2008 Share Posted September 22, 2008 CS1, you question is a little unclear (or maybe it was that pint I had for late lunch). What is it you are wanting to simplify? Your workflow? Your site model? Geometry? Quote Link to comment
CS1 Posted September 22, 2008 Author Share Posted September 22, 2008 (edited) Haha I have a site model which I have created using around 50 3D locis, the site is basically stepped down evenly with the highest point being approx 15m above the lowest point, the site is approx 40m wide by 60m high, I think it is a pretty basic site model, however as soon as I have created the site model from those 50 3D loci my machine becomes extremely sluggish when ever Im on a layer with the site model visible. I have created 3 storey buildings with extensive joinery and various textures and my machine seems to handle these fine. Why is it that the site model slows things up so much (even in top/plan view)? Edited September 22, 2008 by CS1 Quote Link to comment
mike m oz Posted September 22, 2008 Share Posted September 22, 2008 Check the extents of that layer and make sure you have no objects that are well away from the rest of the model. Quote Link to comment
CS1 Posted September 22, 2008 Author Share Posted September 22, 2008 Have just checked and there is only the site model on that layer. Something I have noticed is if I have the view set to top/plan and have the mouse hovering over the white space on the page and use the mouse wheel to zoom in/out the change in view is instant. However if I hover the mouse over the site model and perform the same move it takes about half a second or longer to make one zoom in. Makes no differnce if I have the site model selected or not. Quote Link to comment
