David L Posted March 8, 2001 Share Posted March 8, 2001 Are true type font assignments omitted in DWG-14 exports? I use 3 true type fonts, (Arial, Times New Roman & Technical) on Mac, that are also installed in Windows. The exported drawings open right up in Autocad-14 but all text appears as the "Standard" Autocad font (txt.shx). Is there a way to get the font assignments to export so that Autocad uses them. Quote Link to comment
Ken Posted March 9, 2001 Share Posted March 9, 2001 The answer is probably is simple "no." From what I've learned, the problem is that the DXF/DWG intermediary is still quite proprietary -- not controlled by the good folks trying to improve compatibility with AC, yet *competing* with AC. ------------------ Kenneth Quote Link to comment
