t3aztec Posted September 10, 2008 Share Posted September 10, 2008 I have VW2008 and it all ready has the import for sketchup, but when I import it it comes in as polygons and they are all gray. I also imported the mapping from the same file, but it still comes out gray. Is there a way to import a sketchup file and get ALL the textures that are assigned to it? Quote Link to comment
Guest Frank Brault Posted September 10, 2008 Share Posted September 10, 2008 Sketchup's texture formats are currently incompatible with VectorWorks, however, you can configure the import command to place all objects with a particular material onto separate layers in VectorWorks. This can make the process of applying RenderWorks textures easier. Quote Link to comment
