Wall Tool: walls of multiple construction type/heights
HP Sauce
If a wall is comprised as follows (as an example):-
Split face block up to 3ft elevation
cmu/veneer from 3ft to 9ft elevation
...How would one create this using the wall tool - is it a case of having to make two separate walls or can i merge both of these types in to one for easy manipulation?
Cheers
There is no object intellignece in Vectorworks walls.
They are basically a hybrid object consisting of a 2d double line and a solid (or something like it).
You have to create two separate walls.
And if you want a window with a sill in one and a head in the other you have to hand model both walls.
It's another case where implimenting a common architectural design motif requires tedious workarounds only to result in a brittle model.
In general, Vectorworks walls are using the same software technology that companies like Softdesk used in 1990 to add architectural features to vanilla AutoCad.
Not surprisingly, Vectorworks suffers from many of the same limitations.
Edited by brudgers
Ok, let me get you straight:
- wall styles and wall components
- create walls from spaces
- create walls from polygon
- door and window insertions
- auto-join
- enable connected walls
- fit walls to roof
- link wall height to layer +/- Z
- visible thickness
- flat or round caps
- reverse sides
- component join tool
Wow, I never thought Autodesk was so advanced in the 90's.
Sorry, budgers, but I believe you're already trolling here.
The technology underlying vectorworks is bascially the same.
Vectorworks uses stand alone scripts to manipulate basic collections of cad primatives. In the case of walls the two primatives are a double line and a solid.
What is needed to model walls is a sophisticated data object not a mashup of two primatives managed by a script. Walls need to contain intelligence for handling windows and doors. Instead, vectorworks trys to handle this in the window and door objects and leaves the walls dumb.
Softdesk had door and window insertion. It was a hybrid object approach like vectorworks. Because hybrid objects were not part of the underlying architecture of autocad the implimentation was not nearly as smooth as vectorworks...there was also a lot less computational horsepower available which may account for part of it.
The fact that wall components require manual joining just indicates a lack of sophistication in vectorworks walls.
That wall breaks have to be removed manually just proves how dumb they are.
Someone suggested to me that architects need to communicate clearly the needs of vectorworks to the programmers at NNA.
While parts of Vectorworks are great, there's an inexcusable amount of crap. I'm not going to pull my punches.
You call me a troll, but I have accurately appraised the situation confronting the OP and the limiations of Vectorworks for handling it.
Even your beloved round endcaps are crap. They don't show up in 3D. It took me 30 seconds to discover this. Apparently that's half a minute longer than NNA spent testing the feature.
And typical of the disappointment I have come to expect with Vectorworks walls.
Edited by brudgers
"Vectorworks uses stand alone scripts to manipulate basic collections of cad primatives. In the case of walls the two primatives are a double line and a solid."
You're probably talking about an un-styled wall. I just ungrouped an exterior brick wall and I came out with 10 lines, 3 polygons and one polyline. How do you explain that?
"That wall breaks have to be removed manually just proves how dumb they are."
I don't know about you, but walls seem to (gasp) magically heal on their own in my copy of VW. I think I only get to use the wall heal tool whenever I need to break up some wall joins or when VW is too dumb to know that I want to delete several windows and doors.
"Someone suggested to me that architects need to communicate clearly the needs of vectorworks to the programmers at NNA.
You call me a troll, but I have accurately appraised the situation confronting the OP and the limiations of Vectorworks for handling it."
Please don't change the subject. Although I would agree that NNA needs to work on a load of bugs, we're only talking about "dumb" walls here. You're only making yourself look more like a troll.
"Even your beloved round endcaps are crap. They don't show up in 3D. It took me 30 seconds to discover this. Apparently that's half a minute longer than NNA spent testing the feature."
Well at least it's there. Revit, AFAIK, doesn't even have that feature.
