mdilday Posted March 2, 2001 Share Posted March 2, 2001 How can I have the lines connected to an object move and stay connected to the same points of an object that is moved? Quote Link to comment
Hannes Posted March 2, 2001 Share Posted March 2, 2001 quote: Originally posted by mdilday: How can I have the lines connected to an object move and stay connected to the same points of an object that is moved? I hope i understand you right... You want to move some objects and want one end of a line moved together with them? Use the 2d reshape tool for this purposes. Look at the manual for it's use. HTH, Hannes Quote Link to comment
Jeff Lietz Posted March 2, 2001 Share Posted March 2, 2001 quote: Originally posted by mdilday: How can I have the lines connected to an object move and stay connected to the same points of an object that is moved? If you select both the object and the lines and then group them together, they will then act like a single object. Quote Link to comment
