standard office symbols
I am creating a standard details (i.e.-eve detail, footing detail,etc) library that our office can use on a regular basis. You know, so we don't have to keep drawing them over and over again. Could anyone give me some ideas on how to organize the library so we dont have to sort through hundreds of details?
Thanks in advance.
You can use foldrs:
Building Products
00 - Procurement & Contracting Reqs
01 - General Requirements
02 - Existing Conditions
03 - Concrete
04 - Masonry
05 - Metals
06 - Wood, Plastics, & Composites
07 - Thermal & Moisture Protection
08 - Openings
09 - Finishes
10 - Specialties
11 - Equipment
12 - Furnishings
13 - Special Construction
14 - Conveying Equipment
21 - Fire Suppression
22 - Plumbing
23 - HVAC
25 - Integrated Automation
26 - Electrical
27 - Communications
28 - Electronic Safety & Security
31 - Earthwork
32 - Exterior Improvements
33 - Utilities
34 - Transportation
35 - Waterway & Marine Construction
40 - Process Integration
41 - Material Processing/Handling Eq.
42 - Proc. Heating/Cooling/Drying Eq.
43 - Process Gas/Liquid Handling...
44 - Pollution Control Equip.
45 - Industry-Specific MFG Equip.
48 - Elec. Power Generation
I would organize the details according to the type of building construction. Wood, masonry-block, masonry-brick, steel, mixed steel and wood, etc.
Within those categories, I would then organize them by level: below grade walls, footings, floor to footing, 2nd floor, 3rd floor (if it's different from 2nd floor), and roof details.
Also, I found that pieces of details which can be assembled into complete details sometimes makes things easier. I used to do that with AutoCad all the time. Even if the parts aren't perfectly sized, you can stretch them to fit. I had cross sections for all the standard steel members, wood members and trusses. Then I could plop them in and assemble a detail.
There are all kinds of possibilities to make the work quicker and easier.
