BLACKLAB70 Posted February 26, 2001 Share Posted February 26, 2001 When I export a pict and print it odd length arcs print as straight line segments. Any remedies for this situation. Quote Link to comment
Guest Posted March 5, 2001 Share Posted March 5, 2001 You might want to check your printer resolution and try a setting higher then 72 dpi if not set there already. You could also be experiencing a problem due to internal accuracy where an object/objects are far away from the drawing area. To test this go to each layer and select all then Fit to Objects. If you find the objects either move them closer to the drawing area or delete them. Hope this helps. Mike S. NNA Quote Link to comment
