carpalmer Posted August 15, 2008 Share Posted August 15, 2008 I put my windows and doors on a class that gets turned off on the Structural plan VP, but then just get an "interrupted" wall at the window opening. What I want to achieve is 2 lines indicating wall faces below, and not just a blank area where window goes. Is there a way to play with PIO class parts classes to get what I want? Tried with sills but didn't work... pls advise thx carpalmer Quote Link to comment
Pat Stanford Posted August 15, 2008 Share Posted August 15, 2008 What you probably want is rather than turning off the class the doors are in you want to turn on the Ceiling-Main class and turn off the Sills class. You may also need to assign classes to the trim and turn that off also if you don't want it to show. Try it and see if it will give you what you want. Pat Quote Link to comment
Markus Barrera-Kolb Posted August 16, 2008 Share Posted August 16, 2008 In the OIP for your door and window objects, make sure that you selec "Full break with caps" under "Breaks". This way, when you turn off the door and/or window classes, the wall breaks will have end caps. The one drawback of this, I think, is that these breaks will show up when you want to do a reflected ceiling plan, where of course you don't want to show them. Would be nice if this was something you could override in a viewport. I also don't quite know whether WinDoor objects give you greater flexibility in this regard -- worth checking into. The disadvantage of Pat's approach, if I understand it correctly, is that the jambs will still show up (thus capping the wall breaks), and that's information which is not really wanted on a structural plan. Quote Link to comment
