Wall Join Big Problem Please Help
CS1
You can't join walls which are collinear because there is no way the program can determine where the join should occur. ie should it be at one end, in the middle, at the end etc. When there is a need to butt join the ends of two collinear walls use stretch to get the ends of the walls to where you require.
Sorry I don't mean "join" as in the tool "join", I have been stetching one wall into another or using the slit tool to cut one wall in to three and changing the class of the middle wall to say "removed" and then dashing.
The walls seem to appear fine for a short time then all of a sudden all the walls that are joined like this shoot off the page.
How are people doing plans for renovations with this problem?
I start off with all my existing walls in a a class "existing remaining", then I go round the plan and trim section of these walls and change there class to "removed" so on my existing floor plan VP I can do a class override and show them as dashed and on my proposed floor plan VP I can hide them.
...walls that are joined like this shoot off the page.
Try duplicating all the existing walls at this point, group them, re-class to your demo/remove class, then lock them. You will still get some unwanted interaction between the grouped and locked walls (VW needs a stronger lock, apparently!) as you draw and move new walls around, but things are a little more manageable.
Should be fine, except now no need to re-class the removed bits- they're already there under the existing.
Edited by Chad McNeely
