I3erk Posted August 11, 2008 Share Posted August 11, 2008 is there any way to trim 3d objects while they are grouped together. for example if i want to trim a group to have a 45 degree angle on one corner, how would i do this if they are in 3d and if they are grouped together (there are too many objects and too time consuming to do individually) Quote Link to comment
Pat Stanford Posted August 11, 2008 Share Posted August 11, 2008 No, you can't trim a group. You can edit the group and then select and trim multiple object there. I find the Split tool is best for this. How many object are you talking about? Should they all really be separate pieces? Or would you be better off making a single (or maybe a few) solid additions to cut down on the individual parts count? Pat Quote Link to comment
Benson Shaw Posted August 11, 2008 Share Posted August 11, 2008 Use the Split tool (in the basic tool palette - It works on 3d objects, too) If all target objects are in one group, dbl click to enter the group Set the view plane perpendicular to the cutting plane Apply the Split tool in Line Split or Line Trim mode. This cuts all ungrouped objects crossed by the line, selected or not. Resulting object will show as Solid Section in OIP. Dbl Click the object to reveal and edit its orig objects and cutting plane. Any target objects which are groups will not be cut. (ie you can group an object to protect it from cutting) If manipulating groups is a problem, apply classes to the objects, ungroup and manipulate class visibility. Post back if this does not work. And please create a signature (My Stuff tab near top of forum window) so posts indicate your VW version and computer info. -B Quote Link to comment
Ray Libby Posted August 11, 2008 Share Posted August 11, 2008 You can also hold the Alt key down to split selected objects only. Quote Link to comment
