CS1 Posted July 31, 2008 Share Posted July 31, 2008 Is it possible to create a sectional viewport of say a cube but have that viewport at an angle say left isometric? Basically what Im trying to achieve is, I have a 3D Waterproofing Detail, I have several viewports all from roughly a left isometric view, in one of the viewports I want to give the impression of the object being ripped in half so I can see whats happening inside. I have attached an image I found on the net, it is basically what im wanting to achieve Quote Link to comment
M.CH Posted July 31, 2008 Share Posted July 31, 2008 You could do 2 viewport sections with projection selected "Oblique Cabinet Projection" or one of the others avialable and match them up to how you want them HTH Quote Link to comment
CS1 Posted July 31, 2008 Author Share Posted July 31, 2008 I tried that and got the attached results??? Quote Link to comment
Pat Stanford Posted August 1, 2008 Share Posted August 1, 2008 This may be a good time to do a detail instead of trying to use the model. Copy the detail and do a Section Solids on it. If you need both halfs, duplicate it twice and section both halfs. Pat Quote Link to comment
islandmon Posted August 1, 2008 Share Posted August 1, 2008 Recalling the old "Cut3DSection Procedure"... Quote Link to comment
CS1 Posted August 3, 2008 Author Share Posted August 3, 2008 So is it not possible to achieve the attached image using a viewport? Quote Link to comment
