Robert Nichols Posted February 11, 2001 Share Posted February 11, 2001 When selecting Layer Options -> Modify others, only occassionaly do I get the correct result. Usually, elements on visible non-active layers remain numb to my cursor. At times, I'm able to get it working by switching from the arrow tool to the line tool. The line tool seems more likely to acknowledge the presence of elements on non-active layers. When this works, I can then switch back to the arrow tool and it will work as expected. Is there a workaround for this? Quote Link to comment
barkerla Posted February 13, 2001 Share Posted February 13, 2001 Robert, Modify others only works when all the layers are the same scale. Not sure if you are aware of this but that seems to be the only reason I've come across that modify others doesn't respond to. Quote Link to comment
dlstudios Posted February 13, 2001 Share Posted February 13, 2001 Also, snap & modify only works if the various layers have the same view. Top view on the active layer will not snap to plan view on another layer. Quote Link to comment
