2008 viewer et al
Tools menu>Customize Toolbars>check Comment & Markup Toolbar.
But... I seem to have opened a can of worms here, a PDF exported from VectorWorks has Usage Rights disabled. The PDF needs to be opened in Acrobat Pro and have Usage Rights enabled to be able to use the Comments & Markup tools in Acrobat Reader.
I'm going to file a bug.
Foxit Reader will open any PDF & allow you to mark it up. However, the free version will toss an "evaluation version" stamp onto the PDF. If both parties are fine with that...side-effect, then it will be a workable solution.
Just make sure to tell them to right click the toolbar area & turn on:
-Commenting Tools
-Drawing Markup Tools
-Typewriter Tools
Good luck!
