Creating print PDF and export DWG vectorscript
I think this was looked at a few weeks ago and "We" (as a group) decided that there is no way to access the PDF functions via VS. The following was posted to the VectorScript List by Charles Chandler:
Ordinarily, for plug-ins you use the filename (minus the extension), as determined by looking in the Plug-Ins folder:
DoMenuTextByName(?Batch Print?, 0);
DoMenuTextByName(?Export PDF (Batch)?, 0);
For features that are not plug-ins, you have to use the DoMenuTextByName selectors, as found in the VectorScript Appendix:
http://scs-inc.us/Other/VSFR/Appendix/appendix.html
I?m not seeing ?Export PDF? in the Plug-Ins folder, or in the DoMenuTextByName constants, so there?s no way to call that one. The other two ?should? be callable.
But in a quick test, I can?t get either ?Batch Print? or ?Export PDF (Batch)? to work, though I can call other VectorScript menu commands. So I don?t know what to tell you, expect that you?re probably out of luck. Sorry. :/
You should be able to do the DWG export using the DoMenuTextByName('DXF/DWG Export',0); command.
Pat
This might be a very basic question but I have a batch runner in applescript and I am trying to include a simple print vectorscript for a selection of vw files. The applescript works fine but it breaks down when it tries to run the vs.
Does anyone have a very basic print file script that I can test out?
Thanks
