Door insertion problems
Hi -
We're having a problem with inserting a door symbol into a wall. To avoid repetitive work, we usually copy a door with the settings we want and then insert the copy into the wall.
Typically, we don't have any issues with inserting windows or doors into walls; however, we've encountered a situation where a door (or window--the problem is also showing up with window insertion) cannot be inserted into a wall in our model. To be clear, we've tried testing this issue out on a plain generic 6" wall with no other objects on top or below the wall to interfere with the insertion process. The door simply floats over the wall, without inserting. Windows also have the same problem.
We are able to insert doors and windows when using the door or window tools, but now VW doesn't seem to want to let us insert these objects as we have done for years.
We've tried quitting and restarting both VW and our machines with no results.
Anyone have a clue on how to fix this?
J
