basic scripting help
I';m trying to learn a bit of scripting and find the logic within, but withouot luck so far. It think i get allready wrong at refering naming.
I just vectorscript exported an object. how do you refere a parameter with the script, like scaling the object or something.
Here the objectcode
Procedure LoadFile;
VAR
hatchName, gradientName, objectName:STRING;
result, index, segmentIndex:INTEGER;
boolResult:BOOLEAN;
top, left, bottom, right:REAL;
BEGIN
{VectorWorks Version 12.5.1 (64620)}
NameClass('00-aanduiding');
BeginGroup;
NameClass('0');
ClosePoly;
PenSize(10);
PenPat(2);
FillPat(1);
PenFore(4369,4369,4369);
PenBack(65535,65535,65535);
FillFore(0,0,0);
FillBack(65535,65535,65535);
BeginPoly;
CurveTo(-2.679491924311261,-10.000000000000005);
CurveTo(2.679491924311269,-10.000000000000005);
CurveTo(7.320508075688748,-7.320508075688746);
CurveTo(10.000000000000005,-2.679491924311269);
CurveTo(10.000000000000005,2.679491924311261);
CurveTo(7.320508075688748,7.320508075688738);
CurveTo(2.679491924311269,10.000000000000002);
CurveTo(-2.679491924311261,10.000000000000002);
CurveTo(-7.320508075688738,7.320508075688738);
CurveTo(-10.000000000000002,2.679491924311261);
CurveTo(-10.000000000000002,-2.679491924311269);
CurveTo(-7.320508075688738,-7.320508075688746);
EndPoly;
Marker(0,0.078735,35);
MoveTo(0,10.000000000000002);
LineTo(0,-9.999999999999892);
MoveTo(9.999999999999778,-0.000000000000002);
LineTo(-9.999999999999659,-0.000000000000002);
PenSize(2);
MoveTo(0.606217782649082,-0.000000000000002);
LineTo(0.606217782649082,9.981608086876578);
FillBack(8738,8738,8738);
BeginPoly;
ArcTo(0.303387885506254,10.000000000000002,0);
LineTo(0,10.000000000000002);
LineTo(0,-0.000000000000002);
LineTo(0.606217782649082,-0.000000000000002);
EndPoly;
FillPat(0);
FillBack(52428,65535,65535);
TextFont(GetFontID('KCAPSVtBold'));
TextSize(18);
TextFace([]);
TextFlip(0);
TextRotate(0);
TextSpace(2);
TextJust(1);
TextVerticalAlign(1);
TextOrigin(0.403384191623047,6.457722222222182);
BeginText;
'N'
EndText;
EndGroup;
SetZVals(0,0);
{End of Creation Code}
{Default Attributes}
PenSize(2);
PenPat(2);
FillPat(1);
Marker(0,0.125,15);
PenFore(0,0,0);
FillFore(0,0,0);
{End of Default Attributes}
END;
Run(LoadFile);
Here's a few simple additions, so hopefully you'd get the general idea :
Added a VAR named scalefactor, a simple dialog to enter it's value.
Added a line after the group is created, where scaling takes place.
Procedure LoadFile;
VAR
boolResult:BOOLEAN;
scalefactor : REAL;
BEGIN
scalefactor:=RealDialog('Scaling factor :','1');
DSelectAll;
BeginGroup;
NameClass('0');
ClosePoly;
PenSize(10);
PenPat(2);
FillPat(1);
FillFore(0,0,0);
BeginPoly;
EndPoly;
PenSize(2);
BeginPoly;
EndPoly;
FillPat(0);
TextSize(18);
TextFace([]);
TextFlip(0);
TextRotate(0);
TextSpace(2);
TextJust(1);
BeginText;
'N'
EndText;
EndGroup;
Scale(scalefactor,scalefactor);
SetZVals(0,0);
PenSize(2);
PenPat(2);
FillPat(1);
Marker(0,0.125,15);
PenFore(0,0,0);
FillFore(0,0,0);
END;
Run(LoadFile);
