dailewis
Helios database information in Vectorworks
Can anybody help?
Is it possible to import Helios/NPS plant data into vectorworks to replace the standard plant database?
Thanks
Dai
By using the FileMaker based Plant Database, you should be able to import almost any external data into the database, and then generate plant lists for use in VectorWorks.
The main thing you need to know is what format your data is in, where the various fields are and how they match up to the proper fields in the plant database. Check the
File > Import Record > File menu
command in the Plant Database to see the various formats supported.
If you need specific help in doing this, just drop a line.
Judah Warshaw
Nemetschek North America
We have successfully imported plant data into the VW plant database.
We are particularly interetested in the NPS data which the plant data base has editable fields for and for which we have now got data in. However, when it comes to using this data in Vectorworks from Get plant data there doesn't appear to be a field for the National Plant specification data to come under? Is there someway of putting these fields into vectorworks?
